Old 12-14-2013, 04:51 AM   #1
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Ceiling / Headliner Delamination
I notice that, in a small area over the sink in my MH, the glue has failed on the headliner and it is sagging a fraction of an inch. From my experience with Airstream trailers, I know that this can progress to where whole sections of the headliner will come loose and droop or sag.
What have you used for a "fix"? I noticed, by doing a search on the list, that one person used white thumb tacks and another used wood strips and plastic caped screws. Over time, what has worked the best? I assume all the ceiling surface under the vinyl/foam headliner is thin plywood. Is this correct? What is a good source of the plastic capped screws?
Any additional comments appreciated.
Thanks!
Sam
Airstream12557 is offline   Reply With Quote
Old 12-14-2013, 11:55 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
The first thing you should do Sam is inspect the roof for leakage in that specific area, and all other areas. Skylights, vents, any other items that have penetrated the original roof, and the roof to wall seams.
Once water touches that LAUN ply, that is used throughout the f/g models, it will continue to wick (in all directions) until the water supply is diminished.
Early detection and repair is needed, but constant maintenance of the roof area will prevent most problems.
If you have one small area, installation of a smoke detector, or other addon device, will accomplish the task.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 12-15-2013, 07:26 PM   #3
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Thumb tacks
Sam,
I'm to poster of the thumb tack solution. I failed to mention that you should buy the longer white thumb tacks, the 1/4" cheap ones don't go through the ceiling boards far enough.
My longer ones have lasted for years and look like a custom ceiling. On a previous coach I took down all the panesl, scrapped all the delaminated foam off and clued new vinyl headliner material to them. Worked good but tookall my spare time for months. The Tacks are quick & easy and if more drooping occurs, you just add tacks in the new droop area.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 12-16-2013, 04:05 AM   #4
Dave and Paul; thanks for the replies!
I don't feel that the root cause of the delamination is water intrusion. I keep an eye on all roof penetrations and add/replace caulk as needed. But water has a way of finding the smallest point of entry.
I think our delamination is caused by adhesive failure between the vinyl/foam headliner and the wood ceiling. This seems to be common in Airstream travel trailers.
Paul, what do you think was the cause of your delamination? And thanks for the additional information on your "fix".
Sam
Old 12-16-2013, 04:07 PM   #5
Headliner delamination
Simple: The foam backing on the headliner got old and dry and sort of came apart and let go of the glue that held it to the ceiling board. The glue sticks to the board and the weight of the headliner separates the foam. Same reason they fall down in cars.
Take it apart and you'll see that.
Since I've done it the hard way and with tacks, I'll do the tacks again when needed. (Actually it looks better than the original flat panels.)
Paul
Paul
Old 12-17-2013, 03:37 AM   #6
Thanks, Paul. Mine seems to have separated at the glue joint, since I can feel som tackiness when I push up on the small area that has came loose.
Sam
Old 12-24-2013, 03:48 PM   #7
Headliner
Glue joint or foam delamination, your headliner droops. The long tacks are the treatment no matter the cause. (Even if your separated foam has static cling)
Happy Holidays, I hope you get tacks in your stocking.
Paul
Paul
Old 12-24-2013, 04:09 PM   #8
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
We used to use contact cement in a syringe - squirt some under and squish it around, let it dry and than push it down. Only leaves a small needle hole you can't see unless you look for it. Get syringe at pet store.
Silver Hawk is offline   Reply With Quote
Old 12-25-2013, 04:25 AM   #9
Thanks, Silver Hawk!
Sam
Old 01-01-2014, 04:34 AM   #10
2002 27' Safari
Churchville , Maryland
Take a look at this post, http://www.airforums.com/forums/f39/...ing-40416.html. We are very happy with the outcome.
Cable is offline   Reply With Quote
Old 01-02-2014, 03:58 AM   #11
Good thread. I had done a search earlier, but missed this one.
Thanks, Sam
Old 01-24-2014, 12:22 PM   #12
1994 31' Legacy 30
Thanks!
Sam
I had this problem in a few places on my 1994 30'. I found that a quick & simple fix can de done with a 3.5 " wide plastic slat from a vertical blind slipped into the "H" channel, concave side up against the ceiling, with no adhesives or fasteners. The slats are available from any custom blind supplier and can be had in a color to match the ceiling vinyl in any length you need. The slats are easily cut with scissors.
ctatoday is offline   Reply With Quote
Old 01-25-2014, 04:11 AM   #13
CTATODAY, that is a unique solution. I like it!!
Sam
Old 01-26-2014, 12:17 AM   #14
1994 31' Legacy 30
I got my slats from the trash bin, they were from a patio door blind and are long enough to go across the width of the coach. In one location I cut the slat to go from the rear AC to the side wall. I also used some short pieces inside the overhead bins.
Regards,
Cicero
Vinyl (we think) ceiling odor? Skater Upholstery, Blinds, Walls & Interior Finishes 14 07-27-2015 01:17 PM
Running recessed lighting in ceiling Davew Lights - Interior & Exterior 13 10-11-2011 03:39 PM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
Loose interior ceiling Bandits Ribs, Skins & Rivets 5 01-12-2011 05:05 PM
