Old 07-26-2006, 02:33 PM   #1
1994 33' Land Yacht
somersville , Connecticut
ceiling coming apart
My 33 ft airstream land yacht motor home. Ceiling bulging and falling down. Need advise on how to repair, replace or use something else. anyone had this problem? What is recommended or who can repair.
N1eud
n1eud is offline   Reply With Quote
Old 07-26-2006, 09:15 PM   #2
tx-lawman's Avatar
1995 33' Land Yacht
Houston , Texas
I had the same problem. I used small wooden strips (white) from the local hardware store (Lowes) and put them about 6 inches apart across the roof to hold up the existing headliner.
I'll take some photos tomorrow and post them for you.
____________
Troy Marrs
95 Land Yacht 33
tx-lawman is offline   Reply With Quote
Old 07-26-2006, 09:20 PM   #3
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
My folks had the same issue
N1eud
And they fixed it based on another forum member's method/recommendation. See this thread, post # 10:
http://www.airforums.com/forum...ling+motorhome
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 07-27-2006, 01:53 PM   #4
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Drooping ceiling vinyl
There is an easier way.
The original ceiling was vinyl with a foam backing that was glued to the ceiling boards and installed before any cabinets or accessories. The foam dried out and the vinly drooped.
On my previous Motor Home (a classic GMC) I took all the cabinets and accessories down and removed the old vinyl. Then I sanded off the old glue and made new vinyl panels, glued them to the boards and re-installed everything.
IT WAS A AWFUL JOB!
SO, when this happened in the "new" Airstream, I was smarter!!!
HERE IS THE FIX..
Go to the hardware store and buy a couple hundered white thumb tacks.
Yep, regular white thumb tacks.
Start with a dull table knife and make sure the vinyl ceiling material is under the plastic edging strip. Then start with a pattern of thumb tacks across the ceiling, tacking the vinyl back to the ceiling board. I found about an 8" pattern worked great. As it spread throughout the coach, I thumb tacked it back in place and now have a beautiful "Diamon Tuffted Ceiling". You could pay a lot of money for such a fancy ceiling, but I spent $2.29 for 300 white thum tacks and fixed it forever.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Pantry - Door coming open gwsullivan Cabinets, Counter Tops & Furnishings 8 09-23-2017 06:21 PM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
First trip coming up - a long one dmac On The Road... 14 01-09-2003 10:06 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
Airstream T-Shirts jcanavera Our Community 15 08-15-2002 10:14 PM
