Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 12-27-2006, 06:22 AM   #1
Profile:  Bakersfield , California
Question Captains Seat Problem
I recently purchased a 1992 Airstream Land Yacht, and am experiencing trouble with the drivers side captians chair. I released the lever to recline the back and now it will not catch in either the upright or reclined position.
Whats the problem, can anyone shed light on this problem? Is the fix easy and inexpensive or costly? HELP ! !
CarlGeo
CarlGeo is offline   Reply With Quote
Old 12-27-2006, 06:45 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I am never this lucky, but it may just be stuck from non-use. Have you tried lubing it, or simply pushing the lever back down to engage the latches?
(No Longer at Inland RV)
Old 12-27-2006, 12:01 PM   #3
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Do you know the mfg. of the chair? (Flexsteel has a logo on the armrest) I bet a call to the mfg. would yield some good advice - I'm pretty sure that Flexsteel Has a lifetime guarantee on the frame - don't know if that would include the mechanism.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 12-27-2006, 01:04 PM   #4
Craftsman
Guest
Profile:
Posts: n/a
I'll bet the catch is just stuck and not returning after pulling the lever.If you have to pull the covering up to get to the mechanism they are usually just attached with hog rings ( oval pieces of steel) that you can pull apart with pliers. Probably an easy fix.
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 06:40 AM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 10:24 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
