Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 12-12-2011, 05:37 PM   #1
1995 35' Land Yacht Diesel
Durham , North Carolina
Cable for dash a/c & heater
For a 1995 LY 35 diesel pusher. AIrstream part # 690315-03 is for controlling the temperature of air. It is a 106 inch cable & housing that runs from the dash to the heater box. It is ridiculously expensive from AS dealers. Does anyone know of a suitable, less expensive replacement? Thanks, Scott
Scott bono is offline   Reply With Quote
Old 01-20-2012, 09:25 AM   #2
2000 31' Land Yacht
Fort Erie , Ontario
Try a bicycle repair shop. They might have cable/foot.
Steve
is.chowa is offline   Reply With Quote
Old 12-14-2014, 08:28 AM   #3
1977 31' Sovereign
1996 30' Land Yacht
Riverview , Florida
Have you found a replacement yet? I have a 1996 30' gas that also needs a cable of some sort. The one in the rig looks like the housing is original as it fits into the control box with a plastic tab. The problem is that it was safety wired to the control which didn't hold it in place. I don't know what the original configuration was. I tried to just move the cable by hand and it will not budge the lever on the heater box. I can move the lever by hand under the dash but it is stiff. The cable is twisted wire rather than a solid wire cable which I would have expected to be used in this application. Don't know if the PO changed the inner cable to strand wire or what. Any help would be appreciated.
Pete
pryner is offline   Reply With Quote
Old 12-14-2014, 10:05 AM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Just some general thoughts on this.
If the cable binds on too tight a turn, you will probably break off the retainer at the dash control. New dash control needed to repair.
If the system is still intact, but stiff, spray lots of silicone on the cable ends and work the cable back and forth.
It will be the pushing motion that binds the cable.
I added a spring to the heat box linkage to help pull that open. The cable has no trouble pulling it closed.
http://www.airforums.com/forums/atta...0&d=1303399477
Any automotive wholesaler has "CHOKE CABLES" that can be cut to length for this to modify the control, but you will now have an independent control.
You don't show a picture of your control, but I believe they are standard on the 70 -80 Chrysler products, more specific, VANS.
http://www.airforums.com/forums/f313...tml#post981579
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 12-14-2014, 10:20 AM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I got mine from NAPA. it was not specific to my chassis but rather a "universal push/pull cable". If you google that, I think youll find a few sources. you can just get something close to your length with the correct ends on the cable.
mayco is offline   Reply With Quote
2011 International EXT cable hookup not working alozier Audio, Video & TV 6 10-20-2011 03:42 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Portable A/C Heater esmaytum Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-01-2011 08:04 AM
Useless Breakaway Cable Routing overlander63 Brakes & Brake Controllers 40 07-02-2011 11:22 AM
info wanted a/c unit heater controls vacuum pipes? fozzies Mechanics Corner - Engines, Transmission & More... 0 03-04-2011 02:47 PM
