Old 02-01-2016, 01:19 PM   #1
C21Tiger's Avatar
2004 30' Land Yacht 30 SL
Surprise , Arizona
Cab air conditioner fan control
I have had to replace the cab air conditioner fan control twice and now it has failed again. The failure mode is only high speed with no lower speeds. Any suggestions other than replace the switch again or is there a way to be able to check voltages and trouble shoot backwards toward a connections or ??
C21Tiger is offline   Reply With Quote
Old 02-01-2016, 05:58 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Trace wires from back of unit, mine had a fuse on the passenger side left of the radiator. Don't know if they changed it when they switched to the workhorse chassis.
Old 02-09-2016, 09:21 PM   #3
2000 31' Excella
Ontario , Canada
Same on mine 2005 30 slide
woodytwo is offline   Reply With Quote
Old 02-09-2016, 10:03 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Is it the switch or the resistor in the duct?
Brevi tempore!
driver air conditioner AC fan speed JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 09-10-2015 09:47 PM
Air Conditioner fan speed question? bmark Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-12-2012 03:24 PM
Crew Cab vs. Extended Cab moosetags Tow Vehicles 43 02-01-2012 04:40 PM
Extended Cab or Crew Cab 2500HD w/Duramax for TV??? TomR Tow Vehicles 19 01-31-2007 07:27 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 11:43 AM
