Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 10-22-2015, 08:02 AM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Broken Rear Upper Shock Mount
During the winterization process of my 2004 Land Yacht 30, I noticed the curbside rear upper shock-mount was no longer attached to the frame and was hanging down with shock still attached.
It appears that the shock-mount was originally held in place to the frame by rivets. One eye-hole had the metal ripped away, so the mount itself must be replaced.
Anyone experience the same? Better bolted, instead of riveted? Possible cause for the problem? Thoughts on where to get a new bracket; Workhouse has not been overly cooperative in the past.
As always, thanks for any and all input and help. May your winterization process be trouble free.......
Randy
RAG is offline   Reply With Quote
Broken shock mount '96 X-Line Cutter Pusher AdamB Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 12-17-2011 01:47 PM
Upper shock mount sheared off 89 Excella pjg5842 Shocks 0 06-12-2011 08:17 AM
Broken rear shock, bent mount effischer Airstream Motorhome Forums 2 09-27-2009 09:23 AM
Rats, broken shock mount dbj216 Shocks 7 07-04-2009 05:01 AM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 08:06 PM
