Old 01-12-2010, 06:58 PM   #1
jwisland's Avatar
2001 31' Land Yacht
Spokane , Washington
Braking System
Hello all,
New to this site, but have a question. I have a 2001 Land Yacht 30 and have just purchased a 1986 Samurai 4x4 with a Roadmaster StowBar installed. Everything works great....and now I'm looking at a braking system. The toad has a curb weight of 2064 lbs. I'm looking at a BrakeBuddy Classic, with breakaway and wireless indicators included, for $950. Is there any reason, with this curb weight, to look at either a BrakeBuddy Advantage system with added proportional braking for an additional $300, or are there other systems out there that anyone may recommend? I'm a fulltimer.....and expect to be traveling in the neighborhood of 6,000 miles a year. Pros/cons to BrakeBuddy? I know there are a multitude of units available, but I'm not towing a Cadillac Escalade...(Wish I was!)
Any issues involving setting this unit on the floor space given in the 1986 Suzuki Samurai?
Jeff
jwisland is offline   Reply With Quote
Old 01-13-2010, 08:33 AM   #2
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
I just finished researching brake systems and we are having a SMI system installed on our Jeep Wrangler toad this Friday 12/15/10. I will let you know how it works out.
I chose the SMI because once it's installed all you do is turn on a switch in the toad and it is working. You dont have to move it in and out of the toad every time you hook up the tow. The price is about the same as most of the other systems and you can install it your self. I am having it installed by Camping Conection in Kissimmee FL because we are full time and I may not have all the tools needed onboard.
Check it out:
SMI Manufacturing, Inc.
P.O. Box 14040
Evansville, IN 47728
Toll Free: 1-800-893-3763
Direct: 1-812-428-2794
E-Mail: info@smibrake.com
www.smibrake.com
BarnacleBill is offline   Reply With Quote
Old 01-13-2010, 08:49 AM   #3
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I will "second" the SMI system. I did an on-line search and liked what I saw on the SMI system. The local company that installed my tow bar and associated items recommended it highly. I had mine installed in late December on a 2010 Toyota Corolla. After hooking the car to the motor home, all I have to do is flip a toggle swtch near my left foot and we are ready to go. There are no brake activation items to install or uninstall. I will put my system on the road in about a week, but to date I do not have any experience on how it will work. From what I have read, I expect it to be great.
Sam
Airstream12557 is offline   Reply With Quote
Old 01-13-2010, 10:54 AM   #4
jwisland's Avatar
2001 31' Land Yacht
Bill and Sam,
Just called SMI and they would have to send a couple different parts to make it work on my Samurai, but they did state that the Duo unit is now only 7" long and 4" wide, so I "can" mount the control unit in the engine compartment. Is this where you have it mounted? What about the indicator light? Using your backup cameras to see them, or wired up to the dash in your MH?
Jeff
Old 01-14-2010, 06:12 AM   #5
I would guess that my control unit (SMI Brains) are about the size of a reem of paper and is mounted under the hood of the toad. Another small box is mounted over the left foot rest in the drivers compartment of the car. This box picks up the inertial signal that the motor home is breaking. It has a "sensitivity control" rheostat and the on/off toggle switch. There is a small air cylinder mounted behind the brake pedal inside the toad.
The indicator light is mounted on one of the tow bar arms and can be observed with the back-up camera. I assume that it could have been mounted on the dash of the MH, but SMI installation documents show it mounted on a tow bar arm.
Sam
Old 01-14-2010, 07:56 AM   #6
Streamin'
I am headed for the install at Camping Connection in Kisimmee today. They install tomorrow. I have already run a wire from the rear of the rig to the dash and will be installing a light on the dash. We will tave both lights, backup camera and dash.
More after the install tomorrow...
Old 01-14-2010, 04:10 PM   #7
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Jeff, I have the Blue Ox braking system, which is very similar to the BrakeBuddy. If I had it to do over again I think I would go with the SMI system or another brand with a similar format. The Blue Ox is ok but the putting in and taking out and storing the box, can be kind of a pain. Not that it takes that much time, but why mess with it when SMI appears to be much more user friendly for about the same money.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-15-2010, 06:00 AM   #8
Bill, when they installed my SMI unit, the MH's rear view camera lowest position (mine has two positions and I assume yours is the same) showed the windshield of the toad. It would not go low enough to see the SMI tow bar mounted indicator light. The installer made a modification that allowed the camera's lowest position to see the indicator light. I think, but am not certain, that they cut off an interference point on the plastic camera housing. After their modification, I can see the indicator light on the lower camera position and see behind the toad on the high camera position.
As an aside, the installer should give you a large package of information from SMI. The package should include a written installation manual, a DVD of an actual SMI installation, and a CD album of a local Evansville singing group. There was good information in the package about how to adjust the sensitive of the breaking cylinder. I ended up taking mine by the SMI facility here in Evansville to check the adjustment. Mine didn't seem to be coming on soon enough. In fact, I couldn't see the indicator light come on even in a hard MH stop.
There is a plastic plug on a cable that goes into the break away switch on the toad. I pulled out the plastic plug and stored it with the safety cables and other items needed to hook the toad to the MH. I didn't want the plastic plug to "disappear" when the toad was not connected to the MH.
Sam
Old 01-15-2010, 09:25 PM   #9
jwisland's Avatar
2001 31' Land Yacht
Thanks to all for the info!
Bill, how did the install go? I'm having it done next Wednesday and am now planning on running a wire as well to the front dashboard. One 14 gauge "should" be enough...? The installer knows about the tow bar setup and now knows I want it on the coach dash, but didn't mention any extra labor for runing the wire. Good idea to run it in advance. Please post as soon as you have it installed....especially with the dash mount light description!
Sam, I only have a backup camera that is activated when in reverse....so the "camera" option won't work for me, plus I don't trust my eyes looking at a 3" screen at a light, even if I did have a constant rear view camera. Someone should have told me when I was born that my eyesight would get worse with age...
And they told me at the factory that the Duo main box is now 7" long, 4" wide, and 3" high. Bill will hopefully have the correct dimensions after his install. I'm a little worried about my '86 Samurai......may have to bolt the box in vertically next to the brake master cylinder if I want it under the hood.
Gloran, I looked at the Blue Ox and was told by the mechanics I asked that Blue Ox was a nightmare for them....return-wise. Lots of complaints about reliability, apparently. Glad it's worked for you.
Cheers,
Jeff
Old 01-16-2010, 05:13 AM   #10
Jeff, I don't think the main control box has a preferred orientation. Mine is installed vertically (kind of like putting a slice of toast in a toaster). I wouldn't have thought that the installer could have found a spot under the hood for the box, but he did.
As an "aside", I understand that an earlier model of the main control box mounted under the drivers seat. SMI seems to be working toward making the control box smaller to aid in installation.
I like the idea of a light on the MH dashboard. I think the tow bar indicator light will be visible after dark, but I don't do much night driving.
Jeff, that is a "bummer" on the rear view camera only working while in reverse. It is a handy means of seeing what is going on behind the MH while underway.
Jeff and Bill, keep us posted on how the install and check out goes.
It is sure good to see other Land Yacht gas MH owners joining in with comments.
Sam
Old 01-17-2010, 10:25 AM   #11
jwisland's Avatar
2001 31' Land Yacht
Sam, I found the same model wireless "backup" camera in the store yesterday that I haved installed on my MH. Started looking at the instructions....read about splicing into the "rear backup light wiring".......went back home and switched my existing wires over to a "rear lamp", and now I have a full time camera whenever my lights are on. I'm still laughing at myself for not being more creative earlier.
I wonder if they locked Bill in the garage over the weekend?
Jeff
Old 01-18-2010, 05:48 AM   #12
Jeff, congratulations on the backup camera. You will enjoy having the ability to use the camera anytime.
Since the weather warmed up in Florida, we can assume that Bill did not get snowed in.
Sam
Old 01-20-2010, 04:43 PM   #13
jwisland's Avatar
2001 31' Land Yacht
Sam, yes...it is nice to see behind me all the time. Just hooked up the toad and am headed for Coeur d'Alene, Idaho in the morning to have the Duo installed. No word from Bill, so I'll try and post some pics here when it's done.
Jeff
Old 01-21-2010, 06:03 PM   #14
Streamin'
Bill is alive and well in Key West
Sorry to be out of touch but we have been network challenged for a few days. Did a little boondocking in the Everglades.
We are now in Key West and back on the net. The install went well. It took them about four hours to install the whole system. They did a nice job and every thing fits and looks good on the jeep. (I think I an posting pictures )
I installed the light in the dash panel of the coach and the shop installed a six pin cable to replace the four pin we have been using.
The six pin accommodates the existing light wires and the new “coach notification” light wires. I ran two wires (pair), but the shop said I could have run a single wire and used a common ground somewhere under the dash.
So we have not traveled too far with the new system yet but it seems to be working well. I'll post more as we learn more.
A braking question Glenn G Brakes & Brake Controllers 1 09-26-2007 08:49 PM
Hydra Vac braking system question! 7xp Brakes & Brake Controllers 10 08-06-2006 11:50 PM
Braking Problem thripplewood Brakes & Brake Controllers 20 12-10-2005 09:04 AM
Braking Q????? Kstar Brakes & Brake Controllers 3 06-05-2005 02:51 PM
