Old 07-15-2007, 08:31 AM   #1
2002 26' Land Yacht 26
Bedford , Nova Scotia
Brake Fluid Reservior
Hi folks: I've owned a 2002 26' LY for a year. It's a P32 Workhorse chassis. One thing I can't find is the reservior for the brake fluid. The GM/ Workhorse dealer merely said it was under the hood when I asked. Anybody know where it is?
Thanks, Donald
Bedford is offline   Reply With Quote
Old 07-15-2007, 08:45 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
The reason they were vague is because it probably has a remote reservoir, that is, it is not mounted on the master cylinder.
Take a look at the master cylinder, and follow the fill hoses up to the reservoir.
Old 07-15-2007, 08:49 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
As a general rule the reserve is mounted on top of the master cylinder. On the engine side of the fire wall look just above were the brake pedal would line up. It will most likely be a white plastic housing with a black metal top about 2 by 5 in.
2004 Excursion 4x4
Old 07-15-2007, 03:06 PM   #4
1983 30' Airstream 300
Plantersville , Texas
I have a 83 classic MH and the brake fluid reservoir was well hidden on it. Last summer we had a brake line break on the front driver side wheel. After replacing broken line, I had to refill with brake fluid. It was behind the frame and only accessible from inside the front driver side wheel well. Needless to say I needed to be a contortionist to fill with fluid.
I hope that yours is not hidden nearly as well.
Kay and Roy
carnegie1935 is offline   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
