Old 03-15-2014, 07:53 AM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Wvabeer,
What was your experience with mixing 3 and 5?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-15-2014, 08:07 AM   #16
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
My brake fluid got cloudy/clumpy. I thought I had flushed all the 3 out but did not. It just did not mix.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-15-2014, 08:15 AM   #17
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I have one of those mity vacs I am going to change it today and new pads.
Old 03-15-2014, 08:40 AM   #18
1981 31' Excella II
New Market , Alabama
The two fluids don't mix. You can get most of the dot3/4 out and put 5 in. It is hard to get all the old fluid out. What is left of the old fluid will still absorb water but it is still better than pure Dot3/4. The mixture of the two is like oil and water but the mixture still does not compress. NAPA usually has the DOT5 and you can get it online cheaper. The military use to use it in all their vehicles. They say not to put DOT5 in anti lock brake systems and that maybe true. What you might do is change out the fluid to DOT5 then flush again after a few months and that will dislodge more of the old fluid and other junk. I would do this right after driving so the two don't have as much time to separate.
Replacing the DOT3/4 fluid every year or so will work as well. I have found that stuff that is driven a lot works fine with the DOT3/4 and stuff that sits likes the DOT5.
Perry
Old 03-15-2014, 08:51 AM   #19
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Just some pointers that I haven't seen mentioned yet here. I strongly recommend getting a 6 pointed socket to break the bleeder valve loose. Once loose any good open end or closed ended wrench that will reach will work. The bleeder valve seems to be a soft metal and if you round off the corners your job will suddenly become a major effort.
Replacing the fluid is important and should be done every few years. Cheap insurance to keep your brakes working up to snuff.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 03-15-2014, 09:13 AM   #20
dznf0g's Avatar
Oswego , Illinois
Line wrenches are worth the investment. That's all I would use on brake lines and bleeders. 6 point sockets are fine, but gets really messy. With line wrenches you can attache a hose to the bleeder nipple and be neat and still open and close without making a mess.
-Rich-
Old 03-15-2014, 10:05 AM   #21
1981 31' Excella II
It is not a bad idea to break the bleeder screw with a socket so you don't put a side load on it and make it more likely to break off. It might be a good idea to see if you can loosen the bleeders on all 4 wheels before you try to change fluid types. You won't want to get 3 of the 4 wheels done with DOT5 then the last bleeder screw breaks off before you can get all the fluid flushed.
Perry
Old 03-15-2014, 12:59 PM   #22
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
After looking over the brakes still look new and the fluid was a little low but looked clear I think I will wait till I have help. I am going to just have my wife operate my brakes while I bleed. Everything brake related looks fairly new. On another note I have 4 2001 tires that look smooth as new on the sides. at least they are tag and tandem.
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
P-30 Transmission Fluid change interval crazeevw General Motorhome Topics 11 12-08-2011 03:59 PM
Brake Fluid Reservoir Barb H. Land Yacht/Legacy Motorhomes 2 08-08-2011 08:03 AM
