Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 01-15-2018, 10:57 AM   #1
2000 35' Land Yacht XL w/slide
Pound , Virginia
Battery Disconnect Switch
OK guys and gals, we finally have our 2000 Land Yacht 350 XL motor up and running. After a do it yourself de-lamination repair, almost done correctly, changed out our old engine for new one (ouch), and remodeled the bedroom, we finally made it to Eastpoint, FL.
I have a new problem. We came back to the Motor-home to find that the battery disconnect switch was off. As I climbed the stairs I turned the switch off and back on again and it reset. Thought nothing of it until last night. It got really cold and I had my side of the bed warmer on and the furnace was running fine until 4am. I noticed my noise was very cold and the the wife woke up and finally got me to get out of bed. Sure enough the battery disconnect switch was off again. I tuned it to the off position then to the on position and the furnace immediately turned on. Any guesses what is going on?
spgppowell is offline   Reply With Quote
Old 01-22-2018, 07:06 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by spgppowell View Post
I have a new problem. We came back to the Motor-home to find that the battery disconnect switch was off. As I climbed the stairs I turned the switch off and back on again and it reset. Any guesses what is going on?
Don't have one on my MH but you used word reset, meaning you manualyl turned the switch and it came on or you heard a reset in a solenoid? I did have a battery switch on the boat and it was all manual, had a problem with corrosion causing poor connection as switch wasn't used enough..
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 10 06-26-2020 02:35 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 32 08-26-2019 01:23 PM
Battery Disconnect Switch Issue ATE123 Sprinter and B-van Forum 17 08-28-2017 07:31 AM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
