Old 06-18-2007, 03:51 PM   #1
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Battery Control Box on firewall
My 94 Airstream Land Yacht is a diesel pusher with all the electronic's on the
firewall beside the radiator at the rear of the coach.
Above the Battery Isolater is a box maked Battery Control Box. It has a lead to each battery post on the Isolater and appears to be powereed by 110Volt
electrical when using shore power.
Anyway I had one of my new Wal-Mart Marine batteries go dead and had to ultimatly replace it due to a dead cell. In the process fo figuring out why my new battery was dead I noticed a draw from this "Battery Control Box".
It has an 800 # on it so I called and and found that number now serves a
telephone Porn site!
So I disconnected it.
Questions: What is it? Do you all have them? and, Do I need It?
Thanks for any information you can share.
Paul Dobbin in "The Roadhouse"
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 07-02-2007, 08:33 PM   #2
gunworks's Avatar
1995 35' Land Yacht Diesel
Noblesville , Indiana
Paul,
I have this on my coach, but have not messed with it. If it ain't broke.....
I put two Lifeline batteries in last spring and have been very please with them. Expensive, but I don't have to worry about them going dry as they are sealed AGM. My strater truck battery is back behind the left connection storage bin and is also a maintenance free. It has not given me any trouble since '04 when we bought the coach.
95 Landyacht
gunworks is offline   Reply With Quote
Old 07-14-2007, 10:17 AM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Paul, I have the '94LY diesel pusher too. I have a total of 4 batteries - 2 in the back for the chassis and 2 in the front for the coach. The rear batteries are placed one on each side of the rear compartment, and the road side one has a knife switch on the battery post. These two batteries are used mainly to start the engine and the generator.
In the front there are two batteries located under the hood on the curb side, with a knife switch on one of them. The front batteries are deep cycle marine types, and I'm not all that sure how good they are now.
On the rear firewall, top left while looking in are the ATS switches, which we have rewired to convert the shore power from 115v-30 amp to 230v-30 amp (which acts effectively the same as what is referred to as 50 amp service) so that we can run both a/c units when plugged into 50 amp service.
Have you got the manual for your unit? The manual has the entire electical system laid out in block diagrams. Some items referred to in mine don't seem to show up on my MH, though.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
