Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 04-15-2007, 11:54 AM   #1
CarlGeo
Profile:  Bakersfield , California
Bath Accordion Door
My accordion door, between the bath and galley of my 1992 LY motorhome, has began to loose (break) the supporting rollers at the head. When I use the door the supports just break off. Probably a result of the age because the supports are plastic.
Has anyone had this problem, and if so how did you resolve the issue? Did you have to replace the door, or just replace the support rollers.
CarlGeo is offline   Reply With Quote
Old 04-15-2007, 09:09 PM   #2
WayWard Wind
WayWard Wind's Avatar
Profile:  2004 25' Safari
Have you looked at a new Four Winds MH as a replacement? Just kidding. I just couldn't resist the temptation. Sorry I have no answer.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-17-2007, 03:24 PM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Can you post a pic of what you have? It should be a common item.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 04-17-2007, 03:29 PM   #4
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Same thing happened to me on my 2002 Bambi. Until I can find replacement supports, I have just removed the door. Mine door only separates the kitchen from the bedroom so it is less critical that I have a door there than it is for you (i.e., bathroom door).
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 06:09 PM
Looking for Refer. Door Shelf InsideOut Parts Archive 23 06-17-2004 07:08 PM
Main Door buckmaster 1965 Globetrotter 0 10-19-2002 08:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
