Old 09-19-2007, 08:00 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Bad odor lingering inside MH
I have a 2003 AS LY with a lingering, nasty odor (maybe sewer gas). I flushed the tanks several times , adding deodorizores and baking soda mixtgure. No success. The odor continues to overtake the interior. I also installed a 360 degree roof vent to replace the standard cheap vent cover. What could I be doing wrong or not doing that I should be. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 09-19-2007, 08:04 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Is your vent pipe clear - no birds nests? Is a sink trap not installed correctly allowing gasses to come back in through there? Do you use the proper chemicals in the tanks to assist in the decomposition and deodorizing of the wastes? Does the toilet hold some water after flushing to seal the valve off?
Good luck - I had a piece of t-paper hold open my toilet valve once and only a crack and we left for the day shopping - not a nice welcome home.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-19-2007, 08:07 PM   #3
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Make sure your propane detector is working. Check for propane leaks. The odor can be mistaken for sewer gas. A pilot light left on with out being lit?
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 09-19-2007, 08:09 PM   #4
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
If you have a P-trap in your bathroom sink, kitchen sink and shower, is it possible the water in them has dried, allowing the smell to come back up from the black/grey tank?
How about the vent stack from either/both tanks? Are they unbroken/uncracked all the way from the tank to the roof vent? I seem to remember an earlier thread with someone's stack terminating inside their closet.
Sorry you're having issues! That smell is NO fun!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 09-19-2007, 08:59 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, one time I kept on smelling what I thought was sewer odor in our rig. It drove me crazy -- until I finally figured out that it wasn't sewer odor at all: It was a boiling battery. Turns out that the stench of boiling battery acid is pretty similar to sewer gas. (The problem was that our converter went crazy and would not stop charging the battery.)
Lynn
WBCCI 21043
Old 09-21-2010, 06:51 AM   #6
1994 35' Legacy Diesel
Rayne , Louisiana
Images: 8
oo that smell
be carefull could be la=eaky propane they both smell the same .turn off valves see if it still smells after a few hours
YACHTSTER is offline   Reply With Quote
Old 09-21-2010, 07:27 AM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Speaking of leaks, water will bring back any smell that disappear on being dry, carpet and wood hold fungus and mold. AS in the 2000 model used wood in walls and floor that isn't pressure treated.
I would do the vent test with water hose full force on roof down both grey and black.
Make sure your toilet flush valve isn't letting air into living space, our fantasitic fan in the bathroom will pull sewer smell into bathroom if it is on while flushing.
Old 09-21-2010, 08:51 AM   #8
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Check the LP/Furnace
My 345 MH had a bad odor that I traced back to the front furnace. It was the LP gas. When I ripped out the front furnace and capped the LP, the odor went away.
I also had a large bee-hive in one of my furnace vents!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 09-21-2010, 06:27 PM   #9
1995 35' Land Yacht Diesel
Roswell , Georgia
I had a similar experience. My 95 LS Pusher came pre-plumbed for a washer/dryer combination. The trap in the washer drain eventually dried up and allowed tank fumes to escape into the closet in the bathroom and eventually the whole coach. Happened every time we ran any volume of water down the drain. Easy fix... open the access door in the closet and pour a little water down the drain every so often. Remember to do the same with antifreeze when winterizing!
batwingz is offline   Reply With Quote
Old 09-23-2010, 04:32 PM   #10
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Bad smells
We too have suffered from this problem. Sometimes when we're on the road an somebody flushes the toilet the green cloud of TOXIC odor takes over.
We've 1. Flushed both tanks
2. Added odor control
3. Changed odor contril chemicals
4. Added a wind roof vent
5. Checked the stack
Help, it's awful. And it's not propane or engine related, it's SEWER GAS!
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 09-23-2010, 04:44 PM   #11
Splitrock's Avatar
Sioux Falls , South Dakota
Are sewer vents attached and all joints tight?
Gary
Old 09-23-2010, 04:56 PM   #12
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Check for a dead mouse or critter...
mojo is offline   Reply With Quote
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
Interior Odor JMSteward 1970-79 Tradewind 11 10-13-2006 03:48 PM
Interior Odor 640fan Waste Systems, Tanks & Totes 9 09-23-2006 08:57 AM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 12:49 PM
How to get rid of odor happier General Interior Topics 19 07-07-2004 10:34 PM
