Old 09-11-2018, 01:56 PM   #1
LuckyBogey
2004 30' Land Yacht Gas 30
St Marys , Georgia
Backup Camera-Front Fans-Not Working
I'm the new owner of a 2004 LY 30 w/slide. We are very happy with our purchase.
For some reason, I cannot get the front fans and backup camera to work. Also my fantastic fan in the front area is also not working. All were working previously. I'm guessing a fuse problem.
Anyone have any clues?
LuckyBogey is offline   Reply With Quote
Old 09-12-2018, 05:32 PM   #2
2004 26' Land Yacht Gas 26
Thibodaux , Louisiana
Nice Rig
I think I emailed about that rig. Did you get it from a dealer? I would check my fuses first thing mine are in the compartment behind the driver door, the owners manual has a lot of wiring diagrams.
latenite23 is offline   Reply With Quote
Old 09-13-2018, 06:40 AM   #3
LuckyBogey
St Marys , Georgia
Thanks. Private party - North GA. I looked at the fuses under the dash however did not see any that labeled "fans" or "camera"? Did not want to pull out each fuse separately. Will need another plan!
Old 09-13-2018, 07:53 AM   #4
There is fuse bank on the outside of the MH it is located in one of the compartments on the drivers side. I do not have a slide but I would imagine on yours it is located under the slide. My radio had gone out and that is where i located the blown fuse.
Old 09-13-2018, 08:14 AM   #5
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Does the cover to the fantastic fan open but the fan does not spin. If so it may be that the pin that should pop up when open is stuck and or corroded. When my fan fails to spin I take the screen off and use my finger to loosen the pin (pin might be the wrong terminology).
urnmor is offline   Reply With Quote
Old 09-13-2018, 10:19 AM   #6
LuckyBogey
St Marys , Georgia
Thanks. Working now. I think the rain sensor may have been OFF, not sure however fan seems to be working fine now.
Old 09-13-2018, 10:29 AM   #7
LuckyBogey
St Marys , Georgia
Thanks. I will be looking at that outside fuse bank. I believe the below diagram is probably the schematics.
Old 09-14-2018, 08:13 AM   #8
urnmor's Avatar
Berlin , Maryland
First I am glad it is working also after re reading your post it sounded as if the cover open partially and closed or did not open at all. If that was the case you should be able to turn the fan on manually by pulling down on the knob and turning by hand to raise the cover.
Old 09-14-2018, 11:51 AM   #9
I think he is referring to the fans to the left and right up front by the front cabinets. Not the Fantastic Fans but I could be wrong.
Old 09-23-2018, 11:10 AM   #10
LuckyBogey
St Marys , Georgia
Problem Resolved
Problem resolved. Bad Fuse (F2 top right) on outside fuse compartment.
F2 (5 Amp) labeled "CHAS BD LED" also controls Def Fans as well as Backup Camera.
Running lights not functioning after wiring backup camera to trailer capjag Lights - Interior & Exterior 0 06-16-2016 01:36 PM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
Backup / front facing camera upgrade jquayle Sprinter and B-van Forum 5 08-04-2013 10:54 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
fans or no fans goransons Refrigerators 8 12-31-2007 01:21 PM
