Old 12-21-2006, 03:35 PM   #1
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
Aux lights do not work
I have a 2000 LY 35 Gas
The Aux head lights (Fog Lights) Do not work, I have all the paper work and can not find a wiring diagram for this switch,
I checked the switch it works fine,
The bulbs are good,
I just get no power
Is there a fuse some where that some knows about ?
Any help would be great
Rob
myfirstrv is offline   Reply With Quote
Old 11-05-2007, 09:28 AM   #2
myfirstrv's Avatar
Vermilion , Ohio
All,
Its been almost a year and I took the dash apart severl times
Called the mother ship, they did not know where it was said it was wired back to the factory wire harness, probably a ground / relay.
I replaced every relay in the beast which was a bout 12
This weekend I pulled the fog lights, pulled the dash, pulled every fuse I could find,
then I finally found the fuse
The problem was a ford mini fuse #16 on the passenger side fuse panel marked 16 BBP-20 which I think means "for body builder aux power 20 amp"
replaced it worked fine, then I broke the bulb putting it back in place, off to NAPA I went.
Rob
Old 11-05-2007, 10:12 AM   #3
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
Images: 34
Glad you found the problem. Sorry it took a year. Geo...
flcracker
georgezink is offline   Reply With Quote
Old 11-05-2007, 12:03 PM   #4
myfirstrv's Avatar
Vermilion , Ohio
thanks and granted for the time I spent looking for this fuse I could have run new wire new lights everything, but I guess thats not why we are in this !
now I'm off to my next problem !
Finally ready to go and the lights don't work RBolton Lights - Interior & Exterior 9 08-09-2006 06:01 PM
brake/turn lights Herritt Electrical - Systems, Generators, Batteries & Solar 11 04-22-2004 08:12 PM
Original LOOKING interior lights for vintage trailers flamingo-kid1 General Interior Topics 0 04-18-2004 08:04 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 01:58 PM
