Old 06-28-2015, 01:56 AM   #15
2001 30' Classic S/O
2001 31' Land Yacht
Newport , Oregon
I keep reading about the "Rotten Green Switch" but have no clue what part is being referred to. Where is it, what does it do etc. I keep reading threads to learn but although it is often the cause of problems with the park brake I have not read anything specific about the part.
dateem is offline   Reply With Quote
Old 06-28-2015, 04:46 AM   #16
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
The rotten green switch (Pump Motor Switch) is a pressure switch, fabricated mainly from plastic parts. My unit had two, one under the hood and one under an aluminum cover on the chassis (frame rail) just behind the step. the switches are subject to deteriation over time. I bought my first two from a GM parts supplier on line and bought the second two for about a third the cost from Amazon. For my 2004, the following P/N information was correct. I don't know if your year had a different part number:
The GM part number is 15961566. It is stamped on the case. You can order it online at:
Be sure to check price at Amazon.com when you confirm the part number. As a hint, the first sign of failure is when the RGS starts to leak oil.
Do a Google search on Auto Park and you should be able to find lots of information. It has also been discussed on this forum in detail in the past. I would suggest being aware of the system operation, the location of the two switches, and have two spare switches on hand. Failure of the switches will leave you stranded, unless you are prepared.
Sam
Airstream12557 is offline   Reply With Quote
Auto-park problem zagos24 Land Yacht/Legacy Motorhomes 7 04-06-2013 03:13 PM
Auto Park Pressure Switch Wiring Diagram Road Dawg 36 General Motorhome Topics 0 02-04-2012 01:24 PM
workhorse auto park didi Land Yacht/Legacy Motorhomes 0 08-09-2009 07:08 AM
Auto Park jim8860 Mechanics Corner - Engines, Transmission & More... 9 07-13-2005 08:07 PM
Auto Park jim8860 General Motorhome Topics 5 01-22-2004 05:28 AM
