Old 08-20-2013, 09:44 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Auto leveler problem
I have the HWH 610 series. My Right rear jack will pump up but when the pump stops it retracts rite away. where is the check valve to clean or do I need a new one.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 08-20-2013, 03:44 PM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I don't know what they are called, and I don't know if my HWH are the 610 series. But on my levelers, which the tank is under the hood right side I have four T bars that release the pressure from the jacks. You might check and see if they are screwed all the way in not allowing a slow leak.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 08-20-2013, 03:50 PM   #3
Washington , District of Columbia
Hey Guys,
Sorry that I cannot help with you problem, but I like the idea of auto levelers. Is it possible to add these to a new Airstream?
Sorry if I hijacked this thread a little.
dbl0svn is offline   Reply With Quote
Old 08-20-2013, 04:27 PM   #4
1995 36' Classic 36
Ludington , Michigan
Sorta sounds like the solenoid valve is stuck open. Or as suggested above, the manual release valve is open.
Kota is offline   Reply With Quote
Old 08-20-2013, 04:30 PM   #5
1995 36' Classic 36
Originally Posted by dbl0svn View Post
Hey Guys,
Pretty pricy new but doable. You might find a system in a RV salvage yard.
Old 08-21-2013, 05:21 PM   #6
Thanks. I'll have to look into them. They may be to tall for a travel trailer though. Worth a look.
Old 08-21-2013, 06:34 PM   #7
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I guess for now I'm on to use wooden blocks
