Old 09-25-2013, 04:47 AM   #15
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Originally Posted by KYAirstream View Post
Any issue with these starting up at temps below 32degrees? That is, if you haven't been in your trailer and it is less than 32 degrees at start up?
My Hunter has performed flawlessly for a year now, and at all temperatures. To date, it's been the best, and easiest, improvement I've made to "Christine".
Best regards and safe travel to all,
Randy, Pam & Kobi
RAG is offline   Reply With Quote
Old 09-25-2013, 06:26 AM   #16
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Mine was a generic brand I purchased at Home Depot. I didn't need the programmable features and it was only about $19 each. Have worked well for over a year now. Pretty much any digital thermostat will work.
92landyacht is offline   Reply With Quote
Old 09-25-2013, 07:06 AM   #17
RAG
RAG's Avatar
A year ago, the non-programable Hunter I purchased from Walmart, model #42995, was $17.97.
Old 09-25-2013, 09:07 PM   #18
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I replaced mine with the same model Hunter and noticed that the furnace didn't cycle on and off nearly as much. It was a nice improvement over the old one.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 09-25-2013, 09:56 PM   #19
ddruker's Avatar
2000 27' Safari
Palo Alto , California
I bought a decent Honeywell thermostat at Amazon - about $50 - that is programmable and includes an illuminated digital clock, which I was looking for as an upgrade. It very does a good job of reducing cycling at night time - it supposedly learns how fast the space heats up and cools down - so it doesn't over-run and under-run with the furnace - and it also helps save fuel by automatically shutting off completely when it's time to wake up. Using the stove to make coffee and breakfast keeps us plenty warm once we are up.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
Old 09-27-2013, 06:05 PM   #20
2000 31' Excella
Ontario , Canada
Thumbs up
Thanks all for the info. Much appreciated. I'll be replacing mine soon.
woodytwo is offline   Reply With Quote
Old 10-14-2013, 12:21 PM   #21
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I just replaced my OE thermostat (for heat system only) with a Honeywell RTH 111B from Walmart ($24.48). I called help line and they said my two unmarked wires should be on termanals R and W on the new thermostat. I only ran it through one cycle and it worked as expected.
Sam
Airstream12557 is offline   Reply With Quote
