Old 12-30-2008, 04:22 PM   #1
1993 34' Legacy 34
Spring Hill , Florida
Angry Airstream steering problem
I have a 1993 Airstream Legacy 34' deisel pusher with a steering problem. I have new shocks,had the front end checked and all ligned up and put new Good Year tires on it, but the tires seem to help the steering a little but the ride was terrible.The dealer that I got the tires from said that he would like to change the good year tires off and but on toyo tires so I said OK. Well the toyo tires ride great to bad the other tires didn't ride this good but the toyo tires does not steer as good as the good years and they didn't steer the best. The tire size is 8 R 19.5 and the good year tires were 6.5+" wide and the toyo's are only 5.25" wide on the ground. I have a safe-T-steer on the unit to but the thing just doesn't drive like it should it is just all over the road. I have had 4 other motor homes without this problem and I do not know what to do about the problem. I have thought about changing just the front tires to a wider tire again to see if this would help.Maybe like a 225/70/19.5 and maybe adding a track bar to the front ,the back already has one.Does anyone have any ideals?
Aggiehusky14 is offline   Reply With Quote
Old 12-30-2008, 05:53 PM   #2
lynn's Avatar
Does your motorhome have front air bags? If you do you need to verify pressure recomendations,wrong pressure or lack of will affect steering. Have you had the alignment checked?
lynn is offline   Reply With Quote
Old 12-30-2008, 06:07 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
You didn't mention if your steering has a lot of play in it. If it does have you ever changed the bell crank bearings? They can correct road wondering.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 12-30-2008, 08:59 PM   #4
SteveH's Avatar
Common Sense , Texas
If the condition of the front end and steering is good, as in no play, a "wondering" condition on the road is usually a result of too much toe-out. A "darting" condition on the road is usually caused by too much toe-in. If you know the toe-in specs, you can actually check it your self with a helper and a tape measure.
Regards,
Steve
Old 01-01-2009, 02:55 PM   #5
1993 34' Legacy 34
No I do not have air bags only leave springs and I had the front end all checked out and aligned and they could not find any problems with the couch.
Old 01-01-2009, 03:00 PM   #6
1993 34' Legacy 34
When I had the alignment done they got all the play out of the steering and checked the front end for any problem. This was done by a big company that works on the big big trucks so they konw what they are doing I hope.
Old 01-01-2009, 03:03 PM   #7
SteveH's Avatar
If it were mine, I'd take it back and tell them what it's doing. Just because they aligned the front end, doesn't mean they aligned the front end correctly.
Regards,
Steve
Old 01-01-2009, 03:04 PM   #8
1993 34' Legacy 34
The alignment was done by a big trucking company here in florida and it is better now than it was but it is still a bear to drive.
Old 01-01-2009, 05:46 PM   #9
345bill's Avatar
Las Vegas , Nevada
What Steve says in reply #7 are my thoughts exactly. Even the "best" shops make mistakes.
345bill is offline   Reply With Quote
Old 01-01-2009, 10:40 PM   #10
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
How much pressure in the tires? Is it what Airstream specifies?
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 01-21-2009, 03:06 AM   #11
rollin home's Avatar
1992 36' Land Yacht
Oroville , California
i have just had my rig towed in due to what i call a shimmy-wobble
problem in the steering. It lurches, and seems like it will go totally
out of control. this problem is intermittant. i suspect it is suspension,
steering shock, steering gear, tires or axels or bearings.
several mechanics and technicians at the shop have test driven it
and experienced this shaking, but cannot pin point the cause.
this is a 36' Land yacht 1992
any other similar problems known to any of you?
Laurel
rollin home is offline   Reply With Quote
Old 01-21-2009, 08:25 AM   #12
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I'm not familiar with that coach. What kind of chassis does it sit on?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 01-22-2009, 04:07 PM   #13
1992 36' Land Yacht
it is new to me...sort of..i have had it several months but only had it out of the shop for a couple of weeks. all the paper work is in it and it is in the shop (again) now.
it has a Chevy engine (454?)
maybe someone else more familiar with these beasts can answer the chassis question.
(cactus hug?! ouch!)
Old 01-22-2009, 04:52 PM   #14
BLACK FARGO's Avatar
1988 34' Limited
Dashwood , Ontario
I drove a Freightliner once that acted like that and again it had alignments but it wasn't until we replaced the steering box that it was driveable again.
BLACK FARGO is offline   Reply With Quote
Sloppy Steering... Auretrvr Classic Motorhomes 46 11-12-2006 01:23 PM
Power steering problem on my "NEW" 345 JBK Mechanics Corner - Engines, Transmission & More... 19 10-23-2006 08:54 AM
My first vintage airstream and first problem m00d Our Community 5 08-23-2005 03:56 PM
Re: steering Orland Dewey Airstream Motorhome Forums 0 11-24-2003 04:02 PM
