Old 11-22-2011, 08:52 AM   #1
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
Air bags LY
I see air fittings just above the radiator - should air pressure be adjusted based on the ride or is there a set psi one should hone in on?
JMSx2 is offline   Reply With Quote
Old 11-22-2011, 09:10 AM   #2
Airstream specs call for 55 psi in the front air bags.
Old 11-22-2011, 09:18 AM   #3
jackson center , Ohio
The normal pressure is 90lbs. For late model(2001 -2006) LY MH"s I believe pre 2001's was around 60lbs.
Schu is offline   Reply With Quote
Old 11-24-2011, 09:08 AM   #4
2000 31' Land Yacht
Fort Erie , Ontario
Air Bag Pressure
My ASLY 2000 manual says 70 PSI. But that is no longer a problem as I have replaced the airbags & springs with the SS springs. She now rides 'nice' following alignment. Bags were leaking and a pain to keep to pressure. Had to replace front tires as well.
Steve
is.chowa is offline   Reply With Quote
Old 12-30-2011, 09:29 AM   #5
1998 31' Land Yacht
AURORA , Colorado
What is a SS Spring my man said air bags are the way to go
Big Denny is offline   Reply With Quote
Old 01-02-2012, 01:22 PM   #6
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I believe Steve is referring to Henderson's Super Steer Coil Springs. I switched mine three years ago and have been very satisfied with the change.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-02-2012, 02:27 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Thanks, getting ready for the road, need to check pressure, should try to remember to do it when I check the tires. When they are low, steering feels like it is floating, shows up as drifting in lane even when the wind isn't blowing. I use 55 pounds.
Old 03-15-2012, 11:20 PM   #8
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
My Workhorse manual says 90# for rv chassis and I've had a much smoother drive with this pressure. Also have Super Steer and and Steer Safe that were added by the orginal owner. The steer safe had loosened up & the coach was very "drifty" until my mechanic found & fixed it. The Banks product makes a big difference in performance though: no slowing up the little hills I've used so far, even with the toad.
Cliff & Andrea,
One 17 YO cat, but she stays home
TerraYacht is offline   Reply With Quote
Old 03-17-2012, 04:06 PM   #9
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
The manual says 90lbs, but I have my '04 LY set at 70lbs, and it feels just about right.
RAG is offline   Reply With Quote
Air bags for my Dodge Bert Gildart Tow Vehicles 9 10-02-2011 12:10 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
Air Bags Airstream12557 Land Yacht/Legacy Motorhomes 3 07-25-2011 04:15 AM
Air compressor silverdream2 Classic Motorhomes 9 06-22-2011 10:29 PM
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
