Air Bags In the front coil springs
I have a 2003 AS LY with Workhorse with 8.1 engine. The other day I checked both air bags. The RH side was 55 PSI the LH side 0 PSI. I serviced both to 60 PSI. The next day, and the next, the same thing. The LH side looses the air in about 5 minutes. I assume the LH side either has a hole in it or the line is leaking the air. What bothers me is the MH does not appear to lean or out of balance, and it rides great. This is not the way it should be if one bag is not inflated. I would appreciate your advice and thoughts.
Steve
