Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 07-08-2015, 07:34 AM   #1
1998 31' Land Yacht
Lake Odessa , Michigan
ABS Module
I have a 1998 Airstream Land Yacht 30 ft with the GM 454. My ABS module is bad and GM no longer has this part. Anyone know other sources for this part? GM number is #12477838.
btuinstra is offline   Reply With Quote
Old 07-13-2015, 05:39 PM   #2
1998 31' Land Yacht
AURORA , Colorado
Go to your NAPA store they can help you
Big Denny is offline   Reply With Quote
Old 07-24-2015, 08:03 PM   #3
1998 31' Land Yacht
ABS Module
Haven't been able to repair or locate an ABS module for my 1998 P30 Motorhome. GM says it is an obsolete part. Is it safe to disconnect the ABS and run without it?
Old 07-30-2015, 11:36 AM   #4
2011 Interstate Coach
Tulsa , Oklahoma
You might try www.modulemaster.com 888-892-0764. Talk to Leslie. I gave her the p/n you have posted but it does not come up with that number. But she did indicate she thinks she knows which one it might be, If not she indicated that they MAY be able to rebuild yours.
Give her a call, good luck
Road Jager
P.S. Your brake system should function properly with ABS offline, you just will not have the anti skid function operational.
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
How do you glue ABS fitting to ABS tank? Mike&Ali Waste Systems, Tanks & Totes 9 12-09-2010 07:19 PM
Looking for Control Module-Coleman Delta TX DataMover Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2009 02:48 PM
Cruise control module bkahler Mechanics Corner - Engines, Transmission & More... 2 01-10-2009 07:16 PM
ignition module will Classic Motorhomes 6 10-18-2006 08:48 PM
Hi Perf Module ALANSD Mechanics Corner - Engines, Transmission & More... 0 05-13-2002 07:03 AM
