Old 10-14-2007, 08:06 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
A/C Shroud Repair
I have two broken A/C Shrouds. I'm thinking these could be repaired as oppsed to buying new ones at over $140.00 each. Has anyone ever repaired a shroud? If so, what materials did you use? Thanks.
Steve
spat61 is offline   Reply With Quote
Old 10-14-2007, 08:18 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
It would depend on what year the shrouds are and what materials they were made from. Some can be be repaired by using fiberglas and some can not. The original condition or age of the shouds would also be a factor in whether they are worth repairing.
Old 10-14-2007, 08:18 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I repaired my fiberglass Armstrong shroud a few years ago and it's still holding. The fiberglass was real rotten and large pieces were missing. I taped cardboard temporarily over the holes and covered the cracks and holes with fiberglass tape and polyester resin. Then I used a can of aluminum spray paint. Looks good from street level and like I said, it's still holding (for now). By the way I think the Armstrong shrouds are about $250.
Old 10-16-2007, 02:49 PM   #4
gunworks's Avatar
1995 35' Land Yacht Diesel
Noblesville , Indiana
Shroud repair
Go to a place like West Marine or any boat supply place. They have many products for repairing fiberglass hulls and are very helpful. I used a two part epoxy filler with a temporary cool seal tape on inside. drys in 20 minutes and then used orbital sander with 150 grit to contour. From street, you can't tell. I then used a polyurethane pain to paint the shroud with a roller. Looks great!
95 Landyacht
gunworks is offline   Reply With Quote
New a/c shroud!! Chas Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-31-2016 03:26 PM
AC cover [shroud] markus Furnaces, Heaters, Fireplaces & Air Conditioning 38 04-29-2014 03:56 AM
shroud fabrication mtnman Furnaces, Heaters, Fireplaces & Air Conditioning 26 02-13-2007 11:49 AM
ac shroud rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 11 03-12-2006 11:34 AM
