Old 06-06-2014, 10:26 AM   #1
1996 30' Land Yacht
Los Gatos , California
A/C fan runs then stops
95 Land Yacht 30 ft, front roof mount A/C fan runs for about 10 seconds then stops. Compressor never comes on. Checked the black capacitor with ohm meter, appears ok. Checked the dual capacitor with ohm meter appears ok.
Removed leads on all and discharged before checking. Measured PTCR as 47 ohms (approx).
Any clues to where to look next?
Unit is Penguin DuoTherm with thermostat in the ceiling vent cover.
Thanks.
Tim
cruzaire is offline   Reply With Quote
Old 06-06-2014, 11:43 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Does the low voltage light come on?
92landyacht is offline   Reply With Quote
Old 06-20-2014, 02:20 PM   #3
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Make sure the capacitors and voltage are good.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 06-20-2014, 03:51 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The compressor would not come on in that short of time so lets look at the fan. How long before the fan will come on again?
If you have an amp meter measure the running current of the fan. If it is high and there is a clickson on the fan motor. It may be going out against the clickson.
I am assuming it is not blowing the breaker.
2004 Excursion 4x4
Old 06-21-2014, 06:24 AM   #5
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Univolt buzzes then stops JoeMahippah Batteries, Univolts, Converters & Inverters 7 12-04-2009 12:03 AM
Fan never stops! I want to sleep... marchesi Refrigerators 6 07-29-2009 12:32 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 04:25 AM
1988 classic 345 runs and stops howardann Mechanics Corner - Engines, Transmission & More... 4 01-05-2003 04:06 PM
