Old 06-24-2014, 06:54 PM   #1
1998 31' Land Yacht
AURORA , Colorado
'98 P30 soft Brake Pedal
I have 1998 LY on a P30 chassis and it has a soft brake pedle, like it is not going to stop you. I have replaced the master and presure bleed the brakes no help. Pads are good just doesnt want to stop real good????
Big Denny is offline   Reply With Quote
Old 06-24-2014, 07:17 PM   #2
r carl's Avatar
Lin , Ne
I would check the rubber brake lines next.
Old 06-24-2014, 08:12 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Did you keep the reservoir full entire time and started at rr, lr, rf, left front, if you did, my next replacement would be like r carl, replace the rubber hydraulic lines. When you say pads are good, did you take off to look at surface? Oil or glaze would not be seen when measuring thickness from side.
Old 06-25-2014, 07:28 AM   #4
2000 31' Land Yacht
Fort Erie , Ontario
The P30/32 weighs in at 16500#, so if you are expecting to stop on a dime -- forget it. At best the brakes are marginal, in my opinion. DaveFL suggests the proper sequence for bleeding and checking for contamination on rotors. Assume you used the DOT3 brake fluid and flushed the system when Master Cylinder was changed. I have speedbleeders installed on my coach, available from speedbleeders.com which makes the bleeding process a bit easier.
DOT3 is hygroscopic (absorbs moisture) and should be changed every 2 years with fresh fluid.
Steve
is.chowa is offline   Reply With Quote
Brake pedal travel and side pull IPM Mechanics Corner - Engines, Transmission & More... 0 09-27-2009 06:57 AM
Having brake pedal issues and may need rotors SilverToy Brakes & Brake Controllers 10 06-25-2007 04:43 PM
Brake Pedal Stuck To Floor Chaplain Kent Mechanics Corner - Engines, Transmission & More... 14 09-24-2006 12:03 PM
1986 345 AS MH Brake Pedal Travel Jim Tyrney Mechanics Corner - Engines, Transmission & More... 8 04-03-2004 04:47 PM
Brake Pedal Supposed To Be HARD? fangthorpe Airstream Motorhome Forums 8 11-29-2003 01:10 PM
