Old 07-09-2016, 10:37 PM   #1
Registered User
1996 30' Land Yacht
Benson , Arizona
96 LY 30 - Engine battery not charging from Converter?
When plugged into our house, the Converter keeps the house batteries up fine. But after sitting for a week, the engine battery is at 12.1V. Coach batteries are at 13.5. Pretty sure I have a vampire load or two on the engine side; its on the list to troubleshoot...
When I start the engine, both banks charge. I just identified this as a problem, so have not yet had a chance to see what happens with the generator.
Any other LY 30ish coaches work this way?
pago cruiser is offline   Reply With Quote
Old 07-10-2016, 09:52 AM   #2
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
Yes.converter charges house Batts engine charges all3 through isolator. I carry a small auto charger & when I'm camping w/ hookups I charge the engine Battery. When not in use shut off 12v switch by door.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 07-10-2016, 11:13 AM   #3
Registered User
1996 30' Land Yacht
Benson , Arizona
Thanks Gary.
Coming from the sailboat world, I'm used to converters with dual outputs - house and engine. The manuals I got from the PO were missing a couple pages of schematics - like the ones I need...
While this still seems odd... I guess it's "normal" in the Land Yacht world... Kind of like ventilation fans with roof framing support on only two sides...
I like your solution. When I'm working on the RV, I usually have the radio blasting away - which is fed from the engine battery. .Guess I'll add another charger short term, and when I get to electric projects make sure I get a converter (or inverter with built in charger) with a dual output.
Old 07-10-2016, 05:51 PM   #4
garypk's Avatar
1998 31' Land Yacht
Its normal in campers & moho's. Isolator protects the start battery from being drained. Mine drains from stereo (3amps 7 speakers) & phones, tablet, ipod charging. I have used my aux batt switch many times.
Old 07-10-2016, 05:52 PM   #5
garypk's Avatar
1998 31' Land Yacht
By the way I have a complete book. I might be able to get you schematics & wiring diagram if needed.
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 28 12-16-2017 06:32 AM
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
Intel not charging battery Lothlorian Batteries, Univolts, Converters & Inverters 10 11-22-2008 02:48 PM
OOPS! battery not charging,water hook up spilling into reserve tank? outerbanksdeb Batteries, Univolts, Converters & Inverters 2 08-02-2004 12:40 PM
