Old 05-21-2010, 05:54 PM   #1
1996 30' Land Yacht
Middleboro , Massachusetts
96 Land Yacht doghouse insulation
doghouse insulation falling off [needs replacing] any ideas on replacment materials and where to buy. 454 gas had exaust leaks from manifold causing extream heat buildup.
radee1 is offline   Reply With Quote
Old 05-22-2010, 06:32 AM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
If your old insulation isn't in too bad of shape & is just loose or the foil covering is damaged, I was able to repair mine by using reinforced foil tape (the type used for taping insulated duct work) 4"wide, and able to reinforce all edging & center. Perhaps if you need to replace your damaged insulation this same type of insulation used on duct work may work.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Doghouse upgrade Astrodokk Classic Motorhomes 28 12-13-2012 08:57 PM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 01:50 PM
Picture under the doghouse swanky Classic Motorhomes 0 07-09-2009 09:54 AM
Land Yacht doghouse gaskets Taxman Land Yacht/Legacy Motorhomes 4 02-07-2008 07:41 AM
Land Yacht turning into a water Yacht Jacob80 Sinks, Showers & Toilets 10 04-08-2007 08:48 PM
