Old 01-28-2014, 01:50 AM   #1
1996 33' Land Yacht
RANCHO CORDOVA , California
'96 Land yacht 33 ft fuel pump
From under the coach I could see the access plate on the top of the tank. I made a mark on the side of the tank inline with the center of the plate. I then drove a nail up through the floor at the front of the tank. Measured from my mark on the side of the tank to the front and took the measurement inside and went from the nail back and that was where I made my first I inch hole to make sure I was over the center of the plate. My tank is located from side to side, directly in the center of the coach and the plate is in the center of the tank. I made a 6 inch sq hole, but if I were to do it again I would make it 7 inches. 6 was a little snug.
zagos24 is offline   Reply With Quote
Old 01-28-2014, 07:23 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Pictures would help. What did you use to cut the hole?
92landyacht is offline   Reply With Quote
454 fuel pump crazeevw Mechanics Corner - Engines, Transmission & More... 12 12-15-2011 07:07 PM
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 07:15 PM
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 07:13 PM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 06:01 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 08:20 AM
