Old 10-25-2012, 07:34 PM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
'92 landyacht 33
I'm getting ready to go look at this beast, What should I look for besides roof leaks?
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 10-26-2012, 06:51 AM   #2
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
What chassis?
BarnacleBill is offline   Reply With Quote
Old 10-26-2012, 06:56 AM   #3
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
All I know its a gas 454 and has a tag axle
Old 10-26-2012, 09:24 AM   #4
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Not specific to the 33 but here is a short checklist.
Look for:
. Any delamination on the exterior walls and interior (check all cabinets)
. Exhaust manifold leaks
. Proper brake function (verify you have power brakes and power steering)
. Leveling system operational
. All appliances functional (check with more then one high volume LP appliance simultaneously)
(water heater, stove, refrigerator on LP and AC, furnaces, microwave or oven)
. Fresh water pump function and leaks (pressurize system and verify no pump restart after 20 minutes)
. Engine starts with no oil smoke and idles smooth. Road test.
. Verify Dash heat and AC
. Generator starts and produces power (switch over has a 30 second delay)
. Run both roof top AC till cold on generator (takes a few minutes for compressors to turn on so be patient)
. Check condition and age of tires.
. Open all awnings (check fabric and pull cords)
. Check air pressure to air bags using dash gauge (takes a few minutes to pump up from 0 and should settle in around 50 to 70psi. Will not inflate if leveling system has weight off TAG axle)
. Check air horn operation
. Verify keyless entry system (Enter code to open side door then press 5/6 within a few seconds to unlock lower compartments. Press both the 7/8 and 9/0 keys to lock everything)
92landyacht is offline   Reply With Quote
Old 10-26-2012, 09:45 AM   #5
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Thanks a bunch
Landyacht History? Roadrunner Airstream History 8 06-19-2012 08:02 AM
Airstream International 1960 Landyacht Polkabout Classic eBay Watch Airstreams on eBay 0 02-07-2012 01:50 PM
1992 Airstream Landyacht 92landyacht Airstream Registry Discussions 0 11-08-2011 01:50 PM
Minerva :: 1971 Airstream 1971 Overlander International Landyacht rebelstand Airstream Registry Discussions 3 08-22-2011 09:44 AM
94 airstream landyacht landyacht eBay Watch Airstreams on eBay 0 03-21-2011 09:00 PM
