Old 03-12-2015, 10:22 PM   #1
Woodyacme's Avatar
1996 30' Land Yacht
Flagler Beach , Florida
12V out, no power in coach...
After my STUPID act of connecting the 110/30A service to the 220V outlet...
Yes, before you say it, it WAS labeled, & I did not see it until after the event.
I have replaced the switch box in the back of the coach, I have replaced the converter in the front of the coach, but when I am not plugged into shore power, I have no 12v lights, fridge, or other 12v items.
I have checked all the fuses in the front of the coach, I have checked all the breakers in the back of the coach. I have not checked the fuses under the dash, on the left of the drivers seat.. (will check it tomorrow when I have a few moments.
Am I missing something? A component somewhere that I am not aware of?
Leaving for Alabama then to Georgia from Florida tomorrow for 10+ days, I would like to have some power when we are sitting in a parking lot, and for my fridge to work...
Any suggestions?
This is a 1996 Airstream Land Yacht 30Ft.
Appreciate your assistance in advance!
Steve
Steve Woodin
Florida
1996 30' Land Yacht
Woodyacme is offline   Reply With Quote
Old 03-12-2015, 11:11 PM   #2
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
I infer from your description of the problem that your 12V devices work OK when you plug into shore power. Is that right?
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 03-13-2015, 02:44 AM   #3
Woodyacme's Avatar
1996 30' Land Yacht
Yes, you are correct...
You are correct. When not connected to shore, nothing works that is 12V electrical. I have checked all fuses for the "house" but nothing yet for the automotive to the left foot of the driver.
Suggestions?
Steve Woodin
Florida
1996 30' Land Yacht
Old 03-13-2015, 03:49 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Have you checked your house batteries with a meter?
mayco is offline   Reply With Quote
Old 03-13-2015, 04:06 AM   #5
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Is the battery disconnect switch (use/store switch) set to use?
Schools Out is offline   Reply With Quote
Old 03-13-2015, 04:42 AM   #6
Woodyacme's Avatar
1996 30' Land Yacht
I have not checked them with a meter... I will do that.
Steve Woodin
Florida
1996 30' Land Yacht
Old 03-13-2015, 04:43 AM   #7
Woodyacme's Avatar
1996 30' Land Yacht
I do not know of a USE/Store switch in this unit. Where would that be located?
Steve Woodin
Florida
1996 30' Land Yacht
Old 03-13-2015, 05:05 AM   #8
mayco's Avatar
Mine are in the step well. Different model coach but check near the battery compartment.
Old 03-13-2015, 05:12 AM   #9
Rockford , Michigan
Images: 12
Look on the short wall by the entrance: 2 rocker switches labeled chassis & house with use/store options.
Old 03-13-2015, 05:18 AM   #10
Woodyacme's Avatar
1996 30' Land Yacht
I do have a set of rocker switches, when the batt switch is on, I have no 12V power, nothing is working.
I will check the power level of my house batteries. I just connected the new converter that shows it was working, but maybe the batts were down so much that they have not charged fully.
I will connect a battery charger to them to see if that is the issue...
Steve Woodin
Florida
1996 30' Land Yacht
Old 03-13-2015, 05:27 AM   #11
mayco's Avatar
Thats kind of what I was thinking. If you have a meter check the batteries with the coach unplugged from shore power. Then check again with the coach plugged in. Then youll know if the new converter is sending a charge to the batteries and the condition of the batteries right now.
Old 03-13-2015, 05:35 AM   #12
Woodyacme's Avatar
1996 30' Land Yacht
Update, Update, Update...
Just out of curiosity, I put a meter on each of the 2 house batteries, and they both showed 13.5 & 13.6.
I put on the battery charger "just in case" and the little meter on the front showed "almost" fully charged.
I believe that I knocked out something when I connected the coach to 220v power. It stopped working after that.
New "converter" up front, now "switch box" (prob wrong name) in back that switches power from shore to generator, in the back. Checked all the fuses, but when totally disconnected, no 12v power...
I am stumped!
Any other suggestions appreciated.
Steve Woodin
Florida
1996 30' Land Yacht
Old 03-13-2015, 05:40 AM   #13
mayco's Avatar
Hmmmmmmmmm
Old 03-13-2015, 05:48 AM   #14
mayco's Avatar
Thats called a transfer switch.
So with the coach plugged in 12v works.
Coach batteries good.
Something in between the coach batteries and the 12v fuse panel is out of whack.
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
No 12V Coach Power swebster Airstream Motorhome Forums 5 08-03-2004 03:07 PM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 09:53 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
