Just returned home from week on the East Coast in 94 Landyacht. On last day before heading home the Onan 6500 propane genset started as normal, but then produced no A/C power. Ran up to Baltimore to the Onan service center and they checked the voltage at the genset and it registered 120V. Tech indicated that the brushes may have been dirty and frozen in place and road vibration jostled them loose. Ok, so last day of trip home and same thing happened while in Walmart lot for the night. Back on the road and started up the genset and now have 120v power. Finally pulled in the drive today and after shutting down, plugged in the power cord to 30A power box and no 120 V in the coach. No breakers tripped, and the 30A box has the voltage. I'm thinking the Time delay bypass module has failed or partially failed as I can get 120v from the genset sometimes and shore 120v not at all. I pulled the module and it looks like this:
Now what? Where can I get a new one, and is this an Airstream supplied part, or something supplied after market. Onan service people won't work on this as it is not part of the genset.. By the way it is located on the road side beside the bed at rear. Any suggestions?
