Old 05-23-2015, 12:43 PM   #1
2003 26' Land Yacht 26
Redmond , Oregon
03 mh
Have a 26 ft 03 Land Yacht--would like to e-mail chat with like MH owners to compare notes,etc.--my e-mail address is mhardin71@yahoo.com--what is good, not so good, etc.--thank you--miike
mhardin71 is offline   Reply With Quote
Old 05-24-2015, 05:53 AM   #2
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Pleasepost your questions here. There are a number of owners of similar rigs and the discussion might be of benefit to all. You can contact me for any details not of general interest to the group. We have had our 04 30 ft with slide since 2009.
Airstream12557 is offline   Reply With Quote
Old 05-28-2015, 11:43 AM   #3
Redmond , Oregon
table
my MH--03-26 ft-has a sofa and a table--do the driver and passenger captain chairs swivel all the way around so can talk to people on the sofa--not much room for any guests or family-I can get the driver seat turned about 45 degrees--do they need to be all the way forward or all the way back--I have no manuals
thanks
Old 05-29-2015, 05:17 AM   #4
Ours is a 30 ft. 2004, but I assume the driver/passenger seats are similar. To turn the drivers seat fully, first tilt the steering wheel fully up (lever below left side of steering wheel). There are two flip levers at the skirt of the seat and one slide switch. Hold up on the lever that allows the seat to turn and move around until you meet interference, then move the slide switch to move the seat forward or back to eliminate the interference. It may also be necessary to move the seat back into a more upright position to reduce interference. By jockying the three levers/switches, you should be able to position the seat as you wish.
Sam
Old 05-29-2015, 05:49 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I find my passenger seat swivels very easy now that I loosened the crown nut that was tightened to prevent movement, also instead of trying to turn while sitting in it as it swivels, it is easier clockwise when not sitting in it. Drivers seat can swivel but when it is 180 degrees around there is no foot room, couch is in the way. The newer models that have a SO solves the problem.
Old 05-30-2015, 05:02 AM   #6
I usually have my drivers seat at about 135 degrees or slightly less while camped. I use the motor cover as a foot rest and find it a good position for watching TV and catnapping. Glad you found your problem with the overtight nut.
Enjoy your MH.
