Old 08-25-2014, 02:16 PM   #1
KB6YAF's Avatar
Olympia , Washington
Wiring diagram needed for a 1983 Airstream 310
I am working out some 'bugs' in my 1983 Airstream 310 Turbo Diesel Moho. It seems that the brake light switch is not completely depressing when the pedal is at the top keeping the brake lights on, so I am playing around with the brake switch adjustment. I notice that there are two switch contacts plus a rubber hose that goes into it. What in the world does that rubber hose do???? The brake light used to go OFF when I pulled the brake pedal more to the top, and after I "adjusted" the switch closer to the pedal, the brake lights will not go off now. They stay on all the time...!! Had to disconnect the battery for now until I figure this thing out. So, if anyone has a wiring diagram you could post, I'd appreciate it.
Russell
KB6YAF is offline   Reply With Quote
Old 08-25-2014, 05:28 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Send me a pm with your email and I will send you a pdf of the GM motorhome chassis manual. I has the procedure to adjust the brake pedal and switch.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 08-26-2014, 01:25 AM   #3
KB6YAF's Avatar
Thanks Dan. Being new to the Air Forums, I'll have to see about how to pm you.
Russell
'84 310 motorhome 12 volt distribution panel wiring diagram mick32 Lights - Interior & Exterior 3 11-02-2010 12:16 AM
1983 310 coach wiring diagram for main panel scotdo Classic Motorhomes 7 03-08-2009 08:12 AM
1983 Airstream 310 Motorhome Alternator Needed scotdo Mechanics Corner - Engines, Transmission & More... 1 04-14-2008 10:47 PM
Wiring Diagram Needed 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 07-29-2002 01:21 PM
