Old 09-11-2007, 07:48 AM   #1
1976 28' Argosy 28
Lansing , Michigan
Wiper arms
Does anyone know the correct part number, size and part dealer for replacement wiper arms to fit my 1976 28' Argosy? They are rusty and ugly and need a make-over. Thanks in advance.
tandemfish is offline   Reply With Quote
Old 09-11-2007, 07:11 PM   #2
Do some searching on the forum for wiper arm replacements. Someone used Chevy Lumina Van arms that looked pretty good. I found one of them in a junkyard recently and will eventually do something similar. First I have to figure out how to get the wiper arms to park properly
One good way of searching the forums is to use google. Another forum member provided the following info as follows.
In the google search bar type:
lumina wiper arm site:airforums.com
I use this search method all the time now with great results.
Keep us posted as to what you do.
Old 09-13-2007, 06:22 AM   #3
1976 28' Argosy 28
Lansing , Michigan
I'll tell you what I won't be doing. That would buying replacement arms at about $120 apiece. I think I can remove the existing arms and paint them. Yes, I know, not the best fix, but there are other pressing needs for my baby!
Old 09-13-2007, 07:40 PM   #4
Where did you see wiper arms priced at $120 each
We paid a couple of bucks for one of the Lumina arms at a local salvage yard. After I locate a second one I'll look into doing the replacement although I'm in no hurry even though ours are rusty and ugly looking. Makes the rest of the coach look good......
Old 09-14-2007, 04:58 AM   #5
The original wiper arms are obsolete.
According to the original manufacturer, they stopped making that arms several years ago.
Replacement arms that are similair are available, but not cheap, for some unknown reasons.
Old 09-15-2007, 07:37 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
If the only problem with your arms is that they are rusty and ugly, why not take them off and paint them?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 09-17-2007, 03:19 PM   #7
1976 28' Argosy 28
Lansing , Michigan
Chaplain,
Thanks for the advise. I think that is what I will do. Since they are in poor shape and will not budge, do you think I could use a puller from the auto parts store to remove them without a massive amount of damage to them?
Old 09-17-2007, 03:40 PM   #8
Chaplain,
They aren't to hard to get off. A small 2-jaw puller works just fine. Remove the nut and when setting the 2 puller arms make sure you don't hook them all the way against the pivot arm where it comes out of the cowl. There is a shoulder you have to look for. Best bet would be to look at the bottom side of the wiper arm before you install the puller and you'll see what I mean. You only want to pull on the outer edge of the arm.
Does Anyone Have?????? Goucho Arms AirstreamGypsy Upholstery, Blinds, Walls & Interior Finishes 16 11-14-2006 10:59 AM
Need some help with wiper problem guy99 Classic Motorhomes 9 01-31-2006 09:32 AM
Idler Arms Fim White Mechanics Corner - Engines, Transmission & More... 5 10-06-2004 10:43 PM
Zip Dee Arms Too Long DPeakMD Awnings 4 06-07-2004 11:28 PM
