Old 08-11-2010, 12:29 PM   #1
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Windshield
I cracked a windshield last weekend. Is this something that a windshield shop can replace or do I need to take it to a Airstream specialist? I know some things are best done by someone who knows Airstreams but I'm not sure if the windshield replacement is more generic or needs special Airstream knowledge. I need a little guidance before I call my insurance.
Thanks, Dan
Old 08-11-2010, 12:47 PM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
If the piece of glass is flat, you can buy custom-sized laminated glass for about $15/sq ft from many local glass suppliers. It is relatively easy to do it yourself.
There are many guides to glass replacement on the forum.
TX-16
Dave Park is offline   Reply With Quote
Old 08-11-2010, 01:03 PM   #3
Thanks, Dan
Dan.
Any decent windshield shop can replace the windshoeld in your Airstream.
You should also consider replacing the gasket, as a 28 year old gasket will be very hard, risking breaking the new glass. Your insurance company will also cover that part.
Old 08-11-2010, 01:57 PM   #4
_
many threads on this.
the glass IS available, use an EXPERIENCED SHOP with a good rep.
contact your ins carrier, they may have a list of shops to recommend.
OR call a big moho dealer nearby 4 a recommendation.
make SURE the shop orders the correct glass,
the early moho all had the same size 2 piece glass,
but later a/s mohos had a slightly larger glass...
http://www.airforums.com/forums/f156...home-6785.html
http://www.airforums.com/forums/f43/...cost-4906.html
http://www.airforums.com/forums/f156...eld-14831.html
http://www.airforums.com/forums/f310...ent-50110.html
cheers
2air'
Old 08-11-2010, 03:37 PM   #5
Thanks for the responses. I know the windshields are available I just wasn't sure if I needed to go to a dealer or if a competent auto glass shop could do the install. As we all know these aluminum tubes can present some interesting challenges. I just wanted to get my ducks in a row before I call the insurance.
Thanks again, Dan
Smashed Windshield JMChrystie Classic Motorhomes 1 04-22-2008 09:40 PM
Windshield Wipers CarlGeo Mechanics Corner - Engines, Transmission & More... 3 02-17-2008 05:17 PM
windshield wipers jcessna Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 04-16-2007 06:56 PM
