Old 03-19-2014, 05:05 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Window shade in door
Can someone tell me how to make the built in pull down window shade in the door of our 310 stay down. It pulls down just fine but i cant figure out how to make it stay. It may just be broken or missing some type of hook or fastener. Also, if it is broken can these be replaced without too much trouble?
mayco is offline   Reply With Quote
Old 03-19-2014, 06:38 PM   #2
jal4509's Avatar
1977 23' Safari
Commerce , Texas
The door window shade in our '77 has a tab at the bottom with a snap on it. The other end of the snap is attached to the window frame. I'll see about taking a pict of it.
Janet & Jim
"You can buy a cheaper burger, but then you gotta eat it." Texas Burger
jal4509 is offline   Reply With Quote
Old 03-19-2014, 06:48 PM   #3
jal4509's Avatar
1977 23' Safari
Commerce , Texas
Door window shade
Well, the 2nd part of the snap is actually on the door, not the window frame.
Name:	TB2 door shade.JPG
Janet & Jim
Old 03-19-2014, 08:20 PM   #4
mayco's Avatar
Thank you, i figured it was something like that but i didnt notice the snap on the door. The tab on the shade must be long gone but im sure an easy fix. Thanks again!
Old 03-19-2014, 08:45 PM   #5
jal4509's Avatar
1977 23' Safari
Commerce , Texas
Welcome!
Janet & Jim
Old 03-19-2014, 09:19 PM   #6
1982 28' Airstream 280
Redwood City , California
My '82 is the same with a tab on the shade and a snap on the door. I'm also looking to replace my shade with a new one.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 03-20-2014, 05:25 PM   #7
jal4509's Avatar
1977 23' Safari
Commerce , Texas
Let me know if you find a source. Ours is not in great shape, but I haven't researched a replacement!
Janet & Jim
Old 03-20-2014, 05:39 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I bought a shade at big lots that was a close fit. I trimmed the cardboard tube and shade to the right width and reversed the process. I did remove the panel and rerivet it back. Excellent results
Old 03-20-2014, 05:48 PM   #9
The shade is just a standard roll up shade that you can buy at Lowes or Home Depot. They just to cut to fit which is what I had Lowes do for me.
It's the style of shade that you pull down and it's supposed to stay in place. Once down you just pull down slightly to get the catch to release and it should roll back up.
I think the snap is only to keep it from moving around.
Somewhere I've got pictures from where I took my Argosy door apart to replace the hinges and also the shade. If I can find them I'll post them here.
Old 03-20-2014, 07:45 PM   #10
mayco's Avatar
Thanks for all the info. Sounds like the panel has to come off to replace correct?
Old 03-24-2014, 02:52 PM   #11
I don't think so. I'll look at the door from the 310 to see if I can remove the shade.
Old 03-24-2014, 03:21 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
There was no getting mine out without removing the panel. It was just a matter of 20 of so pop rivets.
No big deal!
Old 03-24-2014, 05:51 PM   #13
No big deal!
Yep, just checked the 310 door. Maybe if you're Houdini you might be able to remove the shade without removing the inner skin but I'm pretty sure I can't
Old 03-24-2014, 07:43 PM   #14
mayco's Avatar
Thankyou for checking. I couldnt figure out any way to replace it without removing the door panel either.
Replace opaque door Window with clear? jlight Windows & Screens 10 08-15-2017 08:43 PM
Fixed Window Construction perryg114 Windows, Doors, Locks & Vents 2 12-06-2011 04:32 AM
Exterior/Main Door Doesn't fit frame Angary Windows, Doors, Locks & Vents 1 11-13-2011 06:12 PM
Door sprung AND frame broken Stella Doors & Locks 12 07-06-2011 05:04 PM
Part Numbers needed for Window and door gaskets Dog Doc Windows & Screens 2 04-24-2011 07:30 PM
