Old 10-19-2011, 01:51 PM   #29
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
As you all prepare to replace your front window seals, I'd like to mention the biggest problem that I had, and still have, until I try it again.
When installing the outer "trim seal" into the the groove that holds it, all goes well along the straight sections of window frame. However, when you get to the two curved corners, you will be bending the thickest part of the seal along the outside radius of a curve, and the most delicate edge of the seal on a tighter inside radius. The tendency is for the thin wiper edge of the gasket to "pucker" as you try to go through the curve. I've ended up with a less than "factory" look. I would suggest practicing with a short piece before the final install. I don't know if it's possible to apply a bit of heat to just the thicker side that gets pressed into the groove, or somehow pre-stretch it a little without destroying it. Good luck.
Charly.
streamquest is offline   Reply With Quote
Old 10-19-2011, 02:47 PM   #30
Charly.
Charly.
Not a problem.
Airstream, in production, trimmed off some of the trim seal that rides on the glass, in the area of the 2 radius corners.
That eliminate the "puckering".
Old 10-19-2011, 07:31 PM   #31
Awesome Info Andy!
I have a question, for you Andy, as I worked on my seals today..
How the hell do you get the "Fin Seal", AND the "Vertical Lip Seal" out, and indeed back in?
Do you have to drill out the rivets and remove the Extrusion on the back of the fixed glass?
I spent an hour trying to get the little fin seal out.... and FAILED.
Please enlighten me!
Old 10-19-2011, 11:14 PM   #32
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks Andy,
Hopefully that'll do the trick!
Charly.
Old 10-20-2011, 02:59 AM   #33
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
http://www.airforums.com/forums/f160...air-19059.html
To all those about to 'attempt' their window track seals repair. I haven't tried this yet, but thinking this is the best description yet of how to do this.
Old 10-20-2011, 11:38 AM   #34
Derek,
As best I can see, that info is for the main body windows.
I did or tried one of mine yesterday.
Remember, the fixed fwd section of glass is NLA I hear.... and its a very complex shape!
Getting the sliding glass out was not too tricky...
Push the glass fwd, and pull out the old schlegle, top and bottom.
My Schlegle was a mess... came out in about 5 pieces!
Pull the glass back to about 2" open position
Lift the glass UP, and push the lower edge inboard to clear the track.
Old 10-20-2011, 02:29 PM   #35
Awesome Info Andy!
The vertical lip seal and the trim seal, are simply "pulled out".
The sliding window must be removed in order to remove and reinstall the fin seal.
Clean all the channels out before you attempt to reinstall any of those gaskets.
Old 04-24-2019, 06:16 PM   #36
1978 28' Argosy 28
Killeen , Texas
Window Trim seal puckering
Originally Posted by Inland RV Center, In View Post
Charly.
Not a problem.
Andy The pic you show is very interesting with the edge part of the trim seal cut back. Is there a thread that details how to do this, or some type of jig for cutting it to fit properly?
Thanks. Jay
Hochstrasser is offline   Reply With Quote
Old 04-25-2019, 07:33 AM   #37
Magnet18's Avatar
Churubusco , Indiana
I'm gonna wager a guess that the guy on the airstream line simply wielded one of these and eyballed it
Though I would be pleasntly surprised to learn otherwise
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 04-25-2019, 04:27 PM   #38
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
You hit the nail right on the head ........Regards,Bob
bobmiller1 is offline   Reply With Quote
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
