Old 10-06-2011, 07:17 AM   #15
2006 25' Safari
Buffalo Grove , Illinois
My rear window seal seems to be open at top, heavy rain last few day caused drip in side at top, what to do? Should run a bead of silicone on the outside?
Gregg
airhaus is offline   Reply With Quote
Old 10-06-2011, 07:44 AM   #16
Gregg
Never, ever, use any type of silicone sealer on the exterior.
Use Vulkem, Sikoflex, or Parbond.
Old 10-06-2011, 07:12 PM   #17
Sonia's Avatar
2006 34' Classic S/O
1992 25' Airstream 250
anywhere , New Jersey
How is your new baby?
Originally Posted by joelforeman View Post
Any recommendations out there on where to find driver/passenger window seals for a 325 classic? She's a sweetheart and I finally have her home with a new carburetor. Not cheap btw. But can't seem to locate any replacement seals.
Hey Joel,
How was your trip back from WV? Please let us know about your new baby...
Sonia
Sonia is offline   Reply With Quote
Old 10-07-2011, 09:01 PM   #18
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Hi Pete,
Thanks for the update. Ouch to the windows being siliconed shut! Lucky mine hasn't been 'upgraded' like yours.
Thanks, Derek
Old 10-08-2011, 03:32 PM   #19
Silverton , Colorado
A PO siliconed the windows, seams, fans, and everything else that might leak...still had leaks, and I never did get all the silicone off...just hope the new owner didn't credit me with the left-overs...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-10-2011, 07:56 PM   #20
crazeevw's Avatar
I actually just Spoke to Inland RV...
Here is the list they faxed me to do the whole job right...
16' Fuzzy Schlegle #34696 = $39.20
10' Trim Seal #34708 = $17.00
6' Vertical Lip seal #34713 = $11.70
6' Fin seal #34681 = $15.90
This makes me wonder what it would take to replace each and every window, which I know ALL of mine need!
Discovered this morning, after the HARD rains we had in Central Florida yesterday, that I had water 'standing' next to the lamp on the rear shelf window. Guess I need to figure out how to seal that area. Window is 'kinda' protected from the winds, so know that there wasn't any possible way for winds to blow in the water. Any thoughts suggestions?
Thanks, Derek
Old 10-10-2011, 09:12 PM   #21
Start with the marker lamps!
Keyair is online now   Reply With Quote
Old 10-11-2011, 08:01 PM   #22
crazeevw's Avatar
Thanks Steve, will look at both front and back marker lights after work, and after Home Depot run. Want some of the 'D' channel molding you put on your exterior drawers. Found wet areas along top of front side windows this afternoon. Gotta get all of the water stuff taken care of, before I start ripping up carpet and finding rotted sub-flooring. Thanks, Derek
Old 10-13-2011, 07:12 PM   #23
Sonia's Avatar
window fixes
Can someone post a step by step process/pictures to fix the side windows? Or if there is a thread, can someone post it here?
Thanks!
Sonia
Old 10-13-2011, 08:21 PM   #24
crazeevw's Avatar
Sonia, there is a thread, let me see if I can't find and post here.
Old 10-14-2011, 06:37 AM   #25
Sonia's Avatar
step by step thread
Thanks Derek.
Old 10-14-2011, 07:24 PM   #26
crazeevw's Avatar
Ok, I finally found it. Chaplain Kent posted this over 6 years ago, before he sold his Airstream motorhome and went to an Airstream TT. Before you start, call Andy at Inland RV. He'll make sure you have plenty of material to do the job. Then post here the outcome.
Thanks, Derek
http://www.airforums.com/forums/f160...air-19059.html
Old 10-18-2011, 11:25 AM   #27
Here is a pic of what I got(plus an Awning Scare lamp lens) from Andy...
And for clarification... here is a pic of the different sections.. except the Schlegle..
Left to right...
Trim Seal #34708(goes all around frame of sliding glass)
Vertical Lip Seal #34713 (Goes on the angled Vertical bar)
Fin Seal #34681 (Goes between the fixed and sliding glass)
Old 10-19-2011, 01:15 PM   #28
1982 28' Airstream 280
Redwood City , California
Darn, need another call to Inland to get the three other seals...wish they would have told me when I placed the first order!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
