Old 06-20-2012, 03:06 PM   #1
Brighton , sussex
Which Bargman door lock on a 310
Can anyone tell me the code number of the Bargan lock fitted to my 310?
My inner handle looks broken and I'd like to replace with the right lock. I've heard that these are no longer available.
Loving Life, Chicks, Cars and Mummas Grits baby
montreal is offline   Reply With Quote
Old 06-20-2012, 06:01 PM   #2
That lock was not made by Bargman.
Bargman locks are no longer available.
But, other answers are available.
Old 06-25-2012, 11:36 AM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Don't be so coy, Andy. Mine is about shot, and I'd bet everyone who has a coach our age is going to have the latch fail. Is there a latch available that can be retro-fitted without removing the door and enlarging the opening?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-25-2012, 02:46 PM   #4
Mike.
Working on it.
Have to make sure the kit works OK.
Old 06-26-2012, 12:16 AM   #5
Santa Cruz , California
Images: 12
There is a kit available using a FIC (Home) lock that works well. It's sold by that other Airstream parts place, outofdoorsmart.com. It's the stock FIC 43610 lock in chrome with an outside-locking deadbolt and is supplied with a couple of milled pieces of aluminum sheet stock to close the gaps inside and out, and some Olympic rivets. You need to do a minor amount of carving with a Dremel tool or die grinder on the inside of the door to clear the mounting screws, other than that the door is unmolested. You also need to mill out a small part of the door frame to clear the deadbolt.
There is a problem with the ODM kit. Andy if you do a better version it would be helpful. The gap between the door and the frame is too wide for secure latching with only the slam strike. What's needed is an additional strike plate to mount to the door frame so that both the latch and the deadbolt close securely. Otherwise the door will not stay closed when you drive, unless the deadbolt is latched.
If someone wanted to do it themselves, the latch is only $27 from FIC. They also sell extra keys for $3.50 apiece.
dljosephson is offline   Reply With Quote
Old 06-26-2012, 01:11 PM   #6
Mike Leary's Avatar
Images: 11
Mike.
Working on it.
Thanks, Andy. Let us know.
Old 06-26-2012, 09:12 PM   #7
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Talk about dumb luck, when we first got our 310, I had a problem with our lock. Not knowing at the time the rare lock we have on these, our local RV dealer (and great friends) had a used one on their shelf! 15 bucks for the old lock, and all in-tack, I was a happy camper.
Little did I know how I had hit the lottery with the find!!!
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 06-27-2012, 11:00 AM   #8
Mike Leary's Avatar
Images: 11
You sure did! We were at Oasis R.V. in Tucson a couple of years ago and I asked about the latch. He rolled his eyes and said, "you're not the first person to want one of those".
