Old 11-14-2009, 06:29 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Where's furnace fuse?
I've been trying to get the furnace to light, but to no avail. The blower starts but blows cold air. I attempted about 5 or 6 times, now the blower doesn't even start up anymore. I checked fuses at the Univolt, and all are good. The book doesn't state there are any furnace fuses in the fuse box up front, so what do I do?
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 11-14-2009, 07:34 PM   #2
Use a voltmeter to make sure that a good looking fuse, is indeed good.
You could also have a thermostat problem.
Old 11-14-2009, 08:09 PM   #3
Astrodokk's Avatar
It's not a trailer...see my avatar and signature.
Voltmeter at the fuse, but I don't know where the fuse is! The thermostat clicks like before.
Old 11-14-2009, 08:25 PM   #4
The fuses should be near the Univolt. As I recall the Univolt is under one of the dinette benches.
Take the cover off the thermostat and observe that the contacts are working correctly.
Old 11-14-2009, 09:05 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Could be a bad sail switch, or the igniter board may be bad.
Old 11-15-2009, 12:27 AM   #6
Astrodokk's Avatar
The univolt is under one of the rear twin beds midship, on the passenger side. No other fuse boxes under there except for the univolt ones (six of them). I'll check with a meter and also will take the stat cover off to observe.
Where would the sail switch or igniter board be in a motorhome ('79/'81)? The Suburban furnace is under the galley sink. I see a couple of thermcouple looking wires in there that look good and very clean, but no board.
If I can't troubleshoot this, I'll be taking it to my local RV place to fix. I need heat this winter on my usual treks. I nearly froze a few years ago at the foot of Mt Shasta!
Old 11-15-2009, 06:41 AM   #7
The sail switch and ignitor are parts of the furnace.
Old 11-15-2009, 07:08 AM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
If it's the board, and I bet it is, have them replace it with a "Dinosaur". Something a pro should handle.
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Fuse Box TShepherd Electrical - Systems, Generators, Batteries & Solar 2 01-27-2008 04:53 PM
fuse help !!!! Shellie Electrical - Systems, Generators, Batteries & Solar 3 05-17-2006 06:24 PM
Fuse Box?? dye904 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2005 12:48 PM
Brake fuse Over59 Electrical - Systems, Generators, Batteries & Solar 44 02-13-2005 06:18 PM
Fuse panel bluebonnet Electrical - Systems, Generators, Batteries & Solar 7 08-15-2004 10:42 AM
