Old 05-27-2016, 10:35 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
What to do with empty TV spaces?
I recently bought a 1992 300LE. Both the front and the bedroom tvs are missing. The PO had an Emerson LCD hooked up on the center table, but didn't include it in the rig.
So I'm considering at least an LCD in the front above the dash. And I would only want to be able to connect to local antenna stations wherever I may park.
Eventually when I start using the rig more, then I'll go with perhaps Dish or some techy stuff.
So for now, what LCD and what hardware do I need to get just the off air channels? The original Winegard batwing antenna is up there.
ID:	263352   Click image for larger version
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 05-27-2016, 10:42 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd just measure the spaces and go from there. Remember that the new digital TV broadcast system will work much better with an antenna tuned to the new bands; you may need to replace the batwing.
Old 05-27-2016, 10:52 PM   #3
mandolindave's Avatar
I'm not an actor…but I play one on TV.
But please feel free to proudly display your favorite photo of me, in that space.
mandolindave is offline   Reply With Quote
Old 05-28-2016, 12:57 AM   #4
Astrodokk's Avatar
Uhhh, I don't have a favorite photo of you, so...
I guess an LCD will have to do. I looked into closing off the space with a door and installing a scissor mount with the tv onto it.
I'll research about the digital system and see if I should replace the batwing or be content with a temporary poor signal, as I would only use it sporadically at rest stops.
Old 05-28-2016, 10:12 AM   #5
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
Get a swing arm, that way the TV can be pulled out and turned. Then add an AppleTV, a BluRay and a DirecTV. You are all set.
cazual6 is offline   Reply With Quote
Old 05-30-2016, 08:04 PM   #6
Astrodokk's Avatar
Please enlighten me about Apple tv. What is that?
I know about BlueRay (it's the new type dvd) and I know about Direct or Dish (for satellite signals).
I'm not very techy so I just ordered a 16" LED/LCD combo (DVD) and a swing arm mount. I figure I'll be happy with any signal I can get off air while I'm resting at rest stops. I chose the 16" because it would still allow mw to open the side cabinets while it's locked closed during travel. If I end up not appreciating that size later, I'll go larger.
Eventually, when I start doing trips more often, I'll invest in more technology after I research it some more.
Old 05-31-2016, 08:19 PM   #7
Stay CazuaL
cazual6's Avatar
Reseda , California
AppleTV is many things. Click on the link to read up about it. Useful if you have Apple products. Otherwise, check out the Amazon FireStick. You might consider that as well. Both of these products provide streaming service whenever you have WiFi available.
Old 05-31-2016, 11:22 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Any TV antenna that picks up UHF should work just fine.
The Winegard Batwing on our 83 Excella and the original folding antenna on our 65 Caravel both provide nice digital high definition over the air when available.
Don't go out and spend $ for another antenna until you try the one you have.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-01-2016, 12:12 AM   #9
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Is your new tv 12 volt?
Just curious.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 06-01-2016, 11:40 PM   #10
Astrodokk's Avatar
Yes, it's a 12V TV/DVD combo. Just got the swing mount today and still waiting on the TV. I'll post a pic of the install.
Does Front Hitch Make It Easy To Maneuver In Tight Spaces? Adiredneck Towing, Tow Vehicles & Hitches 17 08-28-2015 05:18 PM
HELP - Need to empty LP tank for export ViewRVs LP Gas, Piping, Tanks & Regulators 7 03-16-2010 07:23 PM
Spaces under doors janetb 2007 Safari SE 17 01-23-2007 05:49 PM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
What's wrong with an empty house? yukionna Off Topic Forum 2 09-12-2005 02:38 PM
