Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-30-2017, 03:01 PM   #1
2001 27' Safari
1995 36' Classic 36
Ambler , Pennsylvania
What to do in snow storm
One knows they are crazy when they drive their moho 500 miles,in less than perfect weather to get it polished. West Coast Polishing meets the East. Sam Bulgara is on a training trip and was nice enough to fit us in.
The pictures are after stripping and a bath. Now indoors and once the ice melts he will start to polish.
The last pic is start of 1st cut
— with Richard Winstanley and Sam Bulgara.
ID:	301632   Click image for larger version
nawwin is offline   Reply With Quote
Old 12-30-2017, 03:23 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Now that is a shine!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-30-2017, 03:39 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I guess mine wouldn't have gotten polished if it meant I had to get it covered in road salt.
CRH is offline   Reply With Quote
Old 12-30-2017, 04:21 PM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Whoa! PUUUUUUURDY!!!
Will you use a clear coat of some sort after the polish? If yes, what will you use?
mayco is offline   Reply With Quote
Old 12-30-2017, 06:17 PM   #5
Reads a lot
Titusville , Florida
Gorgeous!
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 12-30-2017, 08:29 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'd join you, but it's -8F with a wind chill of -19F........I don't think the Mistress will start.
Your 360 will be a lot easier to polish than our Classics are. The windows alone on our Classics take a few days.
Cheers
Tony
Old 12-30-2017, 09:06 PM   #7
2001 27' Safari
1995 36' Classic 36
Tony we had problems on the way out. Stopped overnight on PA turnpike and went on generator. Was very cold and would not start. Batteries starting to get old. Richard tried charging but as cold as it was it would not turn. Finally hooked block heater up and in a little while it started. We will be returning in the same weather which is no fun if anything goes wrong. We will leave it running over night on the way back.
Since we are leaving for a trip the 1st of May we really did not want to pass up the chance to get this done. The other guy we wanted was booked until June.
Nancy
Old 12-31-2017, 07:23 AM   #8
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Nancy, you might want to consider installing a hot water circulator pump. Very inexpensive and worth it's weight in gold. It circulates hot anti-freeze through the entire cooling system so that the engine will start right up and prevents scalding of the cylinder walls, I have been using one for 28 years on my tool truck with great success, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 12-31-2017, 07:44 AM   #9
1995 36' Classic 36
Ludington , Michigan
The Cummins heater actually works very well . It screws into the water jacket on the side of the engine. Warms the entire engine nicely. After about 30 minutes even the top of the radiator is warm. I almost always use mine if it’s below 60 degrees. Saves on warmup fuel. Especially when on campsite power that has already been paid for. Getting the Allison warmed up is probably more important than the engine.
I’ve been thinking of putting an outlet in the engine compartment on a timer. One I can set from the dash with an on time and duration.
Can’t wait to see the shiny coach!
Kota is offline   Reply With Quote
Old 12-31-2017, 07:52 AM   #10
Dazed and Confused
Isuzusweet's Avatar
What Bob is talking about is the Wabasco hot box.
https://www.ebay.com/itm/WEBASTO-AIR....c100005.m1851
Uses diesel to heat the coolant to temp, so you don't have to be plugged in. My neighbour works at Hydro and swears by these hot boxes. He told me that in 15 minutes you can light up your engine easily and they're instantly pumping out heat into the cab.
Don't have to buy this one, as they may make a cheaper one, or you can get it cheaper somewhere else, but watchout as some are also 24V.
Cheers
Tony
Old 12-31-2017, 08:23 AM   #11
1995 36' Classic 36
Cheers
Tony
But campground power is “free”. I run it off the generator if I’m unplugged up in the mountains. Gets cold at night up there and 11,000 foot starts are much cleaner with a warmed engine.
Old 12-31-2017, 08:24 AM   #12
Dazed and Confused
Isuzusweet's Avatar
Actually I should have linked to this one.
https://www.ebay.com/itm/Webasto-The...NaRv9k&vxp=mtr
My bad
Tony
Old 12-31-2017, 09:08 AM   #13
1967 22' Safari
1977 31' Sovereign
Narvon , Pennsylvania
Magic Man!😀
kenwadude is offline   Reply With Quote
Old 12-31-2017, 01:18 PM   #14
2006 39' A-Series
Eagle River , Wisconsin
If I could ask, what is West Coast charging for the polishing job, and how long is it taking? We have a 1994 360 that we'd like to eventually get polished.
Thanks!
ktgsmokey is offline   Reply With Quote
Old 12-31-2017, 04:15 PM   #15
2001 27' Safari
1995 36' Classic 36
Thanks for the suggestions
The starting issue was battery weakness related , resulting from -5f cold soaking all night. Batteries 6 yrs old I plugged in the Cummins block heater and ran the charger till batteries were 12.8 v and it fired off
Should have just let it idle like the Cats and Detroit’s did next to me in parking .
Gen ran fine all night but that doesn’t charge the engine batteries.
I have 120v connections already in place on the rear bumper to plug into extension cords off the gen so you can shut down the the engine and run the gen heat the block and run battery charger or just let the engine idle in the cold and shut down the gen
My stupidity of not anticipating how cold it got that night
Even with aging batteries as long as you have either the gen charging and heating the engine and putting a charge on those batteries or the engine idling,one should be good to go in deep cold overnight in a rest stop
Idling I think is best . I like the hummm of the Cummins in harmony with a Detroit and Cat all night. It’s like a baby’s lullaby. Problem is Nancy doesn’t think so. Ruby and I do just fine
Old 12-31-2017, 06:56 PM   #16
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
Did you guys partially block your radiator in the cold weather?
If not...
What nominal temp was your engine running at?
What fuel economy did you get?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 12-31-2017, 07:39 PM   #17
2001 27' Safari
1995 36' Classic 36
Richard said no blocking and it was running at 170
Old 01-01-2018, 04:45 PM   #18
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
I am also interested in what the cost for polishing was. We have a 1988 325 Classic Moho and are in North San Diego.
3wd67rg is offline   Reply With Quote
Old 01-04-2018, 07:28 AM   #19
1986 34.5' Airstream 345
Alliance , Ohio
OK it's been cold and snowy, any progress on the polishing job?
mehes is offline   Reply With Quote
Old 01-05-2018, 08:23 AM   #20
2001 27' Safari
1995 36' Classic 36
So we finished the polish and are back home. Other than the freezing cold and the poor heater in Moho we had a good trip. 1000 miles everything good. The only problem was toad had a dead battery, but we carried a charger and started it with the coach generator.
It was so cold that Sam was having trouble with the final polish. We agreed to the do the detailing in May when we are in California. It was so cold that some places were not polishing up as well as he would have liked.The coach was indoors but it was still very cold. We were also afraid that the salt and road snow would make a mess of the coach. As it turned out the roads were dry and it got very little salt on it. Over all we are happy but there are a few places that need attention. Biggest problem was getting decals adhesive off.
We will have the detailing done then think about what we want to to put back on it in the way of decals.
The last pic is yesterday back in its storage yard.
Nancy
ID:	301894   Click image for larger version
ID:	301896   Click image for larger version
Big snow storm up the eastern coast in next few days scamp Winterizing, Storage, Carports & Covers 17 01-26-2015 08:08 PM
Towing in a snow storm white laker On The Road... 12 03-19-2014 07:46 AM
Snow storm: Snowmageddon! VtTim Off Topic Forum 5 02-08-2013 08:48 AM
Caught in a snow storm hhendrix On The Road... 15 05-30-2012 03:13 PM
Snow and SNOW.. 53flyingcloud Off Topic Forum 9 01-23-2005 02:32 PM
