Old 09-15-2011, 10:09 AM   #15
Another LPG part?
Was crawling around under my 345 yeaterday, and spotted this odd box on the streetside..
Its directly in front of the LPG tank, and I think it might be LPG related...
Old 09-15-2011, 10:17 AM   #16
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Definitely a GPS tracking system placed there by the man to keep an eye on you. Have there been a lot of "plumbing" and "electrician" vans parked down the street from your house every day for the past few weeks?
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 09-15-2011, 11:24 AM   #17
Sadly, if its on my Motorhome, they would not have had to drive too far to keep tabs on me....
Old 09-15-2011, 11:36 AM   #18
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I showed the pic to my mechanic, he thinks it's vacuum-related with a plastic check valve. It has that "someone has fooled with it before" look.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-15-2011, 11:58 AM   #19
1977 Argosy 24
Milltown , Wisconsin
It's a punuffit! It performs no useful function.
ventport is offline   Reply With Quote
Old 09-15-2011, 01:22 PM   #20
There are 2 of those check valves, one at each end...
There is also some type of electric valve and some wires goind to it... that look disconected..
I also see a pipe in the background that comes down from the drivers compartment... and it looks like it was attached to a T piece but maybe its snapped off...
Another pic, and I can see some words on the cover, but cant read them from the angle...
Now I am gonna have to go crawl under again!
Old 09-15-2011, 02:27 PM   #21
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Open the box, might be a pump, with electric wires disconnected. That pipe coming down from the drivers seat is the emergency toilet outlet. ;-)
Old 09-15-2011, 09:00 PM   #22
Mike!
You(via your mechanic) win 2 points....
Its IS a Vacuum thingy...
But the plot thickens...
Here is a better Pics of it and its attached gubbins...
The clues on the Plastic body say:
Vari-flow Injected
Sensing Control
The pipe coming straight at you, is marked:
Maniforld Vacuum.
I chased that pipe, and it, AND the smaller the pipe that exits forward via the White valve, and the electric powered thingy go up into the engine bay.. where I lost it..
The pipe on the left/rearward exits and goes into a hard pipe that goes onto the Chassis rail, and into a hard pipe, that goes rearward where I lost it... Maybe to to gas tank?
Old 09-15-2011, 09:55 PM   #23
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Might have been a water injection system for the engine. They are used to cool the fuel charge when under load. Water injection was used in aircraft during WWII.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-16-2011, 02:32 PM   #24
You maybe on to something Excella..
I will need to chase down where that rearward bound pipe goes...
If it ends up in the water tank area.. that would be interesting!
So, here is another one...
Up under the dash on the drivers side...
Black box labeled:
Uniden PC22..
There is a cable coming out of it and goes to a multipin plug visible on the lower edge of dash..
I know Uniden makes CB radio's but cannot find a Pc22.. plus there is no readout or dials..
Somewhere I saw a CB where it was all on the Microphone... Channel, and readout etc...
Old 09-16-2011, 03:10 PM   #25
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I think that is the factory CB radio. The units I have seen had all the controls and channel display on the microphone.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-17-2011, 10:25 AM   #26
Really?
That would be cool...
I have searched the internet extensivly and cannot find any info on the PC22 unit, let alone a replacement Mic/handset/display...
I will post in the CB section see if anyone has any ideas.
Old 09-17-2011, 10:47 AM   #27
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
What is this I found in my Airstream?
Greetings Keyair!
I had a Uniden Remote Mount CB radio in 1982. The radio was designed for remote mounting as a theft prevention measure. In my case, the receiver was mounted in the trunk of my 1982 Pontiac Bonneville, and the microphone with all of the built-in controls was hidden in the glovebox when it wasn't in use.
I sold the car in 1983 with the CB so I don't have any of the manuals or other materials regarding the radio any longer.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-17-2011, 11:10 AM   #28
Thanks...
So, I posted in the CB section...
Guess what, LOL...
You know how bad this is gonna go when you try a Google Search for Uniden PC22...
About the fifth result is the post I did in the CB section of the Air Forum 30 mins ago!
