Old 05-08-2011, 07:01 PM   #15
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Metal Subfloor
Keyair,
Just did a complete renovation on the underside of my 1993 LY MH and my metal subfloor was galvanized having a little bit of surface rust. I spray treated the entire underside with two coats of Rust Cutter and then repainted the complete bottom. (sounds a bit extreme) but wanted to try and stop any further rusting. Took a little while but finished last week. Here are a few pictures.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 05-08-2011, 07:12 PM   #16
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Underside of motorhome
While working under the motorhome I noticed this and was wondering if anyone knows what it is - or what it does??
a few more pics
[ATTACH][ATTACH][ATTACH]Click image for larger version
ID:	129406   Click image for larger version
Old 05-08-2011, 08:12 PM   #17
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
That round disc with the cross pattern and a bunch of wires is the level sensor for your HWH leveling jacks. It's mounted on three bolts so you can fine tune it. I don't know if your system is automatic or not but on my manual system it lights up four lites. You raise the corners that are lit up and when all the lights are out the coach is level.
If you have any of that paint left feel free to come play under my coach. My sub panel is aluminum so you only have to do the frame rails and suspension.
Cheers, Dan
Old 05-09-2011, 06:22 PM   #18
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Dan, thanks for the info on my jacks. Actually the project took way more paint, time and work than I thought it would, and I used every bit of the paint up, sorry. But it was one of those projects that I would classify as, once is quite enough. Thanks again Randy
Old 05-09-2011, 06:51 PM   #19
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Very, Very Impressive glorian
The effort and talent of persons posting , and sharing on this Forum is Supreme. to say the Least.
where did you get your coil springs and IPD stabilizer glorian
John H. is offline   Reply With Quote
Old 05-10-2011, 11:21 AM   #20
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
John, I had the IPD front stabilizer and Steer Safe installed at Gary's Safty Center in Bay City Mi. The Henderson front coil springs I bought through Camping World. I think the coil springs made a big difference in ride.
Old 05-10-2011, 11:54 AM   #21
Gloran:
Stunning!
Extreme?
No, just very nicely done... you just set the bar for me!
Great Job!
What paint did you use?
Did you spray it??
Smartstream:
Awesome info on that little box!
I saw the same on mine and thought it was the Door Bell, Until I found the real doorbell under the sofa!
Old 05-10-2011, 03:45 PM   #22
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Keyair,I used all Rust-Oleum oil based paint. I tried spraying and didn't think it worked well getting into all the cracks and opening, plus hard to control and get can in right position. What worked the best was a longer handle 3" roller,(they usually come with a foam roller cover with about 1"diameter) I replaced the foam cover with a longer nap 3"replacement cover same size as the foam cover,that and a assortment of brushes from 1"to 3" mostly 1" with a wooden handle taped onto the brush handle, that enabled me to reach farther,that helped alot.Any ways it was a challenge,only good thing is you get to spend alot of time on your back. Thanks for the compliment. Randy
Old 05-10-2011, 05:33 PM   #23
Oh, Cool...
I did my truck with Rustoleum and a roller....
You be the judge...
Before...
In Progress....
A little spit and polish...
Old 05-10-2011, 05:42 PM   #24
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Big difference, looks alot better. Amazing what a little paint will do.
Old 05-10-2011, 06:49 PM   #25
Which Rustoleum did you use?
Old 05-12-2011, 03:41 AM   #26
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
The Rust-Oleum was high performace oil base. The black I used was flat and the aluminum was gloss. I thought the high gloss in the black would look a little over done for the bottom of a MH, the sheen from the flat black turned out about right.
Abby gets some separation H Top Repairing/Replacing Floor &/or Frame 489 10-18-2016 09:01 PM
Polishing-Black clouds? lucymcdog Cleaning, Stripping & Polishing 19 04-18-2011 03:03 PM
Metal Worker in UK Crabby1 Ribs, Skins & Rivets 4 04-13-2011 12:48 PM
need window screens / metal fabrication in Austin, TX? bgordon Windows & Screens 2 03-31-2011 02:32 PM
'73 sovereign floor metal Flaboy67 Repairing/Replacing Floor &/or Frame 2 01-30-2011 06:51 AM
