Old 09-06-2018, 10:39 AM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
What did this do?
In cleaning my 345 saw this (yellow arrow) & wondered what purpose it served, after seeing the same broken piece on bora77's 370LE (borrowed his photo), seems to be a common issue. How essential are the weep hole covers?
Also, can anyone suggest a source for the rubber that is used as the radiator/body surround, i.e, that forces the air thru the radiator. I'm missing everything on the curb side of the radiator & need to replace.
wimpy is offline   Reply With Quote
Old 09-06-2018, 10:44 AM   #2
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Weep hole covers are a semi elegant method to keep the mud wasps out.
As for the the radiator, it depends on if you are talking about the shroud around the engine fan or the wheel well internal walls.
The shroud will be a junk yard solution. Wheel well internal walls will probably need to be custom made for your setup.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 09-07-2018, 01:40 AM   #3
The engine/radiator shroud is the piece I'm referring to. As a semi-frequent visitor to salvage yards, I'm at a loss as to what kind of vehicle I'd find something that large.
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 10:51 AM
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 02:01 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 10:48 AM
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 08:14 AM
