Old 03-18-2012, 01:33 PM   #15
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by SteSpot View Post
I sure wish I knew about how I have a 1982 24' Airstream motorhome when the factory doesn't know it exists...
You might want to e-mail Tom Clancy and check around for hidden compartments; your orphan could have been made for the CIA.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 03-18-2012, 01:41 PM   #16
Here is some info for you Mike...
Note that they dont list a 0-60 time... Only a 0-50 of 29sec..
I assume its the Non Turbo version!
http://www.airstream.com/files/libra...8b309d0a01.pdf
Paula... they do list a 1980 24' Excella Motorhome at $39,835
Old 03-18-2012, 01:57 PM   #17
Mike Leary's Avatar
Images: 11
Not: the turbo was listed (for the 28 footer) as 0-30mph-10.6 sec., 0-50mph-29.7 seconds. She is not that fast (especially with all the crap that full-timers drag around), but with the overdrive, I can pass farm machinery, if I get a run at it. I believe the longevity of our Isuzu is, since it was basically, a industrial, in place engine (gen sets for fishing boats), I run at, and do not exceed 3200 rpm and Bess has always been a long-haul coach.
Old 03-18-2012, 03:19 PM   #18
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Interesting, I have a 79-81 Airstream service manual and it shows the Isuzu as being 353 cu. in. and 130 hp @3200 rpm and 253 ft. lb. torque @ 1900 rpm. In the above link it lost 2 cu. in. and gained 20 hp and 36 ft. lb. of torque. The manual does not indicate a turbo which I think was offered in 82 while the above link indicates 1980 as the year of the coach. Also the in 82 the GVW increased to 14500 lbs.
Cheers, Dan
Old 03-18-2012, 03:36 PM   #19
Mike Leary's Avatar
Images: 11
Cheers, Dan
Double interesting, because our first mo/ho was a '79 28' Excella, which was turbo-charged, with the Mercedes-Benz style chrome letters.
Old 03-18-2012, 03:39 PM   #20
Sioux Falls , South Dakota
Paula, I wonder if the difference in color is due to fading. Perhaps the odd door was stuck open for several years?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-18-2012, 04:23 PM   #21
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Actually it is the unit--not the tambour door
Okay, it appears that they are in units and put together where the span is longer.....the one that is odd colored is the one on the curb side forward the door. Curbside aft the door are two and they are of the pinker color and all of the ones on the streetside are the same pinker color as the aft ones.....I am not sure what you call them....on an airplane they are overhead bins......the tambours all seem to be the same color......so I don't see how the sun could have done it on all sides and underneath the same on that one unit..........or perhaps it was damaged in an accident and that one was replaced......this is truly a mystery MH...
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 03-18-2012, 04:24 PM   #22
SteSpot's Avatar
1968 28' Ambassador
No Classic badging on the 82 24'
Also, there is no badging.....like Classic or 240 or anything on the outside.
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 03-18-2012, 05:13 PM   #23
Mike Leary's Avatar
Images: 11
"Dum da dum dum." I'd check with NSA, being a Florida coach, who knows what they used it for?
Old 03-18-2012, 05:48 PM   #24
1995 36' Classic 36
Ludington , Michigan
Maybe check with NASA. Might have been used to transport the chimp/human hybrids that pilot our spy sattelites to the launch pad.
Kota is offline   Reply With Quote
Old 03-18-2012, 08:53 PM   #25
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
I don't have my original invoice, but I wonder if the above prices were for the gas version? If, so, I'd guess another $10,000/15,000 would be tacked on for the diesel.?
I've got just about every piece of paper pertaining to the "creation" of my 325 Custom, from blueprints, to specs, to build sheet, but not a single thing that mentions prices. I am under the impression (from some source?, previous owner?) that the Cumins/Allison option in it went for $12k-$14k back in 1990.
streamquest is offline   Reply With Quote
Old 03-19-2012, 01:37 PM   #26
1995 36' Classic 36
Here's the invoice from my "360 A/S PUSHER M/H 1995 C.B. ISLAND DOUBLE J PHANTOM/LL"
Name:	AS 007 (Large).jpg
ID:	153841   Click image for larger version
Name:	AS 006 (Large).jpg
Name:	AS 005 (Large).jpg
Old 03-22-2012, 06:59 PM   #27
Mike Leary's Avatar
Images: 11
Must have been lovely to have had money, in the eighties, to stroll into the AS dealer and pick all the options.
Old 03-23-2012, 12:05 AM   #28
1995 36' Classic 36
Back when $150 Grand would buy you a real nice house.
New Airstream Mhenry2712 Friends of Dorothy 75 11-23-2013 03:14 PM
New LED light kit with sealed lights Dan@LED4RV Commercial Listings 18 08-26-2012 11:18 PM
New Coupler Hitch Lock Hiwheel Joe Hitches, Couplers & Balls 12 05-02-2012 04:04 AM
Getting Safari 'off the ground' for new axle. SafariFaye Axles 9 03-18-2012 04:16 PM
New Airstreamer AirChief Member Introductions 30 03-16-2012 04:05 PM
