Old 10-09-2016, 10:33 PM   #1
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
What Alde system does Airstream Use.
Hello
Does any one know what model number of the Alde system Airstream uses?
Also what control panel is used also.
Been trying to look up Alde USA but it seems the site is down, anyone have any suggestions.
Lets travel is offline   Reply With Quote
Old 10-10-2016, 05:32 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
3010 is the model number of the system. So far the heating aspect is terrific, the advise in the owners manual as well as the factory is to set it and forget it. If trailer is cold it takes a long time to heat it up. Hot water is ok. I am not sure of the control panel model, the website and owners manual only show one type, but there are functions available that AS decided not to put on this system like outside temperature.
Personally I would not change from the Classic you have on your avatar just for this system.
Bud
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-10-2016, 04:25 PM   #3
2014 30' Classic
Alde system
Thanks for the info, I truly love my 14, have done some personal upgrades. At the present cost of a new one I think I'll stick with mine.
David
Old 10-10-2016, 04:41 PM   #4
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
www.alde.co.uk/downloads/alde_3020_user.pdf
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 10-10-2016, 07:57 PM   #5
2014 30' Classic
Thanks for the Info
Is this the model in the Airstream
Old 10-10-2016, 08:59 PM   #6
RonaldC303's Avatar
Washington , Utah
The 2017 Classics have the Alde 3010 system.
http://www.alde.co.uk/downloads/alde_3010_instruct.pdf
Ron
RonaldC303 is offline   Reply With Quote
Old 10-11-2016, 07:25 AM   #7
1954 25' Cruiser
Images: 31
The differences between the 3010 and the 3020 mainly relate to the possibilities of control. In my Airstream Cruiser I have the easier-to-use manual control, without touchcontrol. Am just installing the heating, everything do himself...
Old 10-11-2016, 12:05 PM   #8
2018 33' Classic
Newport , Pennsylvania
How is the system on Hot water recovery. is it as fast as a propane hot water heater?
Earl
EarlM is offline   Reply With Quote
Old 10-11-2016, 08:11 PM   #9
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
You may want to re-post in the Classic trailer section....the Classic motorhome guys are more focused on trying to keep their near 40 year old rigs both able to go, and then stop than 'fancy' hydronic heaters.
That is unless they can be used to get rid of all to surplus heat from the radiator!
martin300662 is offline   Reply With Quote
Old 10-11-2016, 08:21 PM   #10
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Airstream make trailers?? Who knew??
Cheers
Tony
Old 10-12-2016, 12:07 AM   #11
2014 30' Classic
posted it in the wrong section
Can a admin move this to the trailer section, don't know how to do that.
Old 10-12-2016, 03:56 AM   #12
1954 25' Cruiser
Images: 31
For me the "Alde" is ideal: With enough electricity to run electric, with a large heat demand comes to gas, both at the same time. In the summer of hot water with electricity. I have great respect for the gas - my father was in the city of Zurich in the Volunteer Fire Brigade and I experienced many gas accidents.
As a test, I restored a French caravan WITHOUT gas, a Notin Chaumière of 1959th
To cook a kind of chafing dish as for fondue with methylated spirits. The drip tray pan can be heated with electricity. All the insulation replaced with a modern material (x-treme-Isulator) and heated with a Dyson
Regards - Werner
Old 10-12-2016, 04:41 AM   #13
paiceman's Avatar
The 3010 System in the new Classics operates on either gas or electric, Cruiser, however when both are turned on the system choices the electric over the gas. Both can be on, however, the system will run on one OR the other, not both at the same time.
Bud
SAFE TRAVELS
Bud
Old 10-12-2016, 06:51 AM   #14
1954 25' Cruiser
Images: 31
paiceman
www.alde.co.uk/faq.php
"How do I get the best performance from the system in my vehicle?"
= Use the maximum power electric heating AND gas heating..." ?!?
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 03:39 PM
Newbie question: Does Use switch have to be on to charge batteries? bonginator Batteries, Univolts, Converters & Inverters 2 06-15-2010 04:38 PM
Cell Phone Use In An Airstream: Does Anyone Ever Have Trouble Getting a Signal? snog Full-Timing 50 06-05-2010 06:44 AM
Does anyone use this lock? azflycaster Buyer Guidelines 12 11-24-2005 09:20 AM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 12:11 PM
