Old 09-03-2016, 05:56 PM   #1
1987 34.5' Airstream 345
KC , Missouri
Well, bummer, need a Henschen 10 bolt hub
I fried a bearing and the hub on my tag last week. If anyone has a serviceable hub, I'd gratefully buy it!
Otherwise, looking for advice from anyone that has replaced with other options.
Thanks!
Kurt
DHC1 is offline   Reply With Quote
Old 09-03-2016, 07:26 PM   #2
Kurt,
If you can't locate a replacement hub there is a good chance that a good machine shop can repair your damaged hub. Most likely they would repair it by building up the bearing bore surface and then turning the surface back to the correct diameter on a lathe. I've seen hubs repaired this way before.
Good luck!
bkahler is online now   Reply With Quote
Old 09-04-2016, 12:17 AM   #3
KC , Missouri
Brad,
That's a thought that I had as well. A long time ago I worked in a machine shop where we welded crankshafts all the time and thought about that same process here.
If anyone has had some experience with welding and machining a hub, I'd love to hear your experience.
Thanks much.
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 85 11-28-2017 07:58 PM
Bolt Engagement depth from Wheel hub contact point MACINRIC Wheels, Hubs & Bearings 5 11-02-2015 02:41 PM
Major Bummer! guy99 General Motorhome Topics 13 01-12-2008 04:22 PM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
