Old 05-08-2016, 10:35 AM   #1
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Water system upgrade
My old sureflo pump had a slow leak that would accumulate 2-3 drops of water after every shower in it's storage compartment. The pump worked just fine, but the leak was in the head unit. I found a head unit replacement on Amazon for $45. Much cheaper than replacing the whole unit, so then decided I would upgrade with the silencing kit and accumulator.
Before my pump would be heard throughout the coach as that comforting rumbling. Then when using any faucet and after the first 1-3 seconds of running the pump would kick on and the stream would pulse in time to the pump's revolutions. Once I turn the pump off it would continue to run for 4-5 seconds to pressurize the system.
Now when I turn on a faucet I have a 10 second delay before the pump turns on, it will maintain steady pressure for any duration, and is much quieter. Then when the pump comes off it runs for 1-2 seconds. Best of all, no water drips to clean up as part of my shower routine.
I am very pleased with this upgrade. Only regret is that I did not do it sooner.
ID:	262136   Click image for larger version
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-08-2016, 11:00 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Looks like what you did was install an accumulator. A small 2 chamber tank with a rubber diaphragm between the chambers. Depending on the amount of air pressure you inject on the air side will determine how often the pump cycles while drawing water from a faucet.
2004 Excursion 4x4
Old 05-08-2016, 11:04 AM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That is a very good upgrade. Pretty simple to install and well worth the benefits.
Previous owner of our Avion installed a stainless accumulator. Looks good, works good.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about" Rod Stewart (Faces)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 05-08-2016, 11:21 AM   #4
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Perfect! Next up project for sure...my wife is always complaining about the loud water pump so I had been looking at options.
SebasSF is offline   Reply With Quote
Old 05-08-2016, 11:49 AM   #5
SebasSF's Avatar
Any recommendations on pumps? I would like to get the latest from Shurflo.
Obviously 12v, but what is the hose size, psi, gpm... I want to be sure that too much psi will not damage all that impossible to reach hosing.
The Revolution 3gpm 55 psi looks about right...
Thanks, Sebas
Old 05-08-2016, 12:34 PM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I installed that surflo revolution pump, 3gpm 55psi. Ive not been real happy with its flow rate. Ive adjusted it according to the directions and still seems weak to me. One thing to note before you purchase is that pump is recommended for a minimum pipe size of 1/2". All my pipe is factory 3/8". I didnt notice that spec until after I installed the pump. Im not sure if thats contributing to the weak flow rate or not. Just one persons opinion.
Mike
mayco is online now   Reply With Quote
Old 05-08-2016, 12:50 PM   #7
PaulnGina's Avatar
Good Ol' , USA
I just looked at my notes to see what pump we have in the Avion. It's a Shurflo, probably an older one, but is working nicely. It is a 2gpm/45psi pump. I'm sure it is helped a lot by having the accumulator in the system.
PaulnGina
1987 Avion 34W
1987 Avion 34W
Old 05-08-2016, 04:21 PM   #8
Vycan's Avatar
Manhattan , Kansas
I like the sureflo 2088 model series because they have adjustable pressure regulators. I run mine at 40psi with solid pressure, and minimal impact to the system.
Old 05-08-2016, 04:39 PM   #9
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I run Aquajet 55's in the Airstreams....I like a really good shower and don't like the water pressure drop when the wife turns on the kitchen (galley) sink. 85 PSI and 5.3 gallon flow
Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 05-08-2016, 04:40 PM   #10
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1462747198.459640.jpg
Old 05-08-2016, 05:34 PM   #11
Vycan's Avatar
Manhattan , Kansas
You can still get a good shower with great PSI, just get the appropriate nozzle. Of course it all depends on application. I shower in the Airstream like water is scarce.
Old 05-19-2016, 11:28 PM   #12
SebasSF's Avatar
Got mine installed...what a great improvement!
Old 05-21-2016, 03:57 PM   #13
Vycan's Avatar
Manhattan , Kansas
Pics?
Old 05-23-2016, 11:55 PM   #14
SebasSF's Avatar
I'll get some photos next time I'm out there. It looks basically the same, but I used stainless braided hoses I picked up at the hardware store and a small block of wood to screw the tank to as it sits a little higher than the pump.
Audio/Video system upgrade psican Audio, Video & TV 17 02-02-2011 02:08 PM
Electrical system upgrade ck21084 Batteries, Univolts, Converters & Inverters 17 12-04-2010 10:11 AM
1965 Caravel Electrical System upgrade...need help please. teeraniti Electrical - Systems, Generators, Batteries & Solar 27 12-28-2009 05:52 AM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 07:02 AM
upgrade sound system hively General Interior Topics 2 07-15-2004 06:41 AM
