Old 04-10-2014, 07:35 AM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
water pressure
spring has finally arrived in N.Y....time to flush out the anti freeze out of the pipes...fill and drain the potable water tank etc...can not figure out why i have good pressure in bathroom,shower,toilet,sink spray but not on the sink faucet????no leaks anywhere...filters all clean...its very mysterious... no pressure or little neither with the pump on or simply being hoked on garden hose...any ideas as to why?
la nomade is offline   Reply With Quote
Old 04-10-2014, 07:55 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The screen/aerator on the end of the faucet must have plugged with some loose lime or sand in the lines.
Doug and Cheryl
Old 04-10-2014, 08:43 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes the screen is clogged.
Depending on how fast you fill the hot water heater tank you will kick up the silt on the bottom and that silt will move through out the system landing on the faucet screens
2004 Excursion 4x4
Old 04-10-2014, 11:56 AM   #4
la nomade's Avatar
2018 22' Sport
not the case, removed it ,there was some sediment,not much,did not put it back on just to test it....so if there is a blockage its somewhere in the line leading to it....what is the trick to get it out,unclog it ????air pressure???let the water run????
Old 04-10-2014, 12:30 PM   #5
dkottum's Avatar
Is there a valve under the faucet that was partially turned off? Is it cold only, perhaps a drinking water filter? Could the sink faucet valve be plugged?
I suppose reverse pressure may work but you need to take a line loose somewhere within the system to release it. The external water hookup and the pump have anti-reverse valves. And I wouldn't use much pressure, check to see max pressure for the system (65 psi comes to mind).
Doug and Cheryl
Old 04-10-2014, 12:53 PM   #6
la nomade's Avatar
2018 22' Sport
thanks....i ran a thin wire down the faucet ,then i unscrewed the connection under the sink,ran the wire down there too...then put the water back on....the cold water pressure is o.k,the hot a little weaker,but gets better as i let the water run for a long while...so you are right about the sediment...once more thank you all for creative solutions...M
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
